03-13-2020, 02:18 PM | #1 |
Rep 25
Bimmercode - BDCU With Veepeak adaptor?
Getting a message that says I can't access this module with this adaptor. That's weird. Anyone know anything about it? Can I get around it?
03-13-2020, 02:37 PM | #2 |
Petrolhead
1949
Rep 3,521
You’ll need a unicarscan, obdlink or enet adapter I believe. Some modules can’t be coded with other adapters because they don’t have enough memory or something like that.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
03-15-2020, 10:24 AM | #4 |
Rep 25
If you have the app and you look at the purchase adapters under settings you will see which adapters work for which model. If you have g20 you will not be able to access all areas with veepeak. Return and get e sys cable and lightening adapter. Same price and can be used with bimmercode and e-sys
ewanmac188.50 |
03-17-2020, 01:46 PM | #5 | |
Rep 39
03-18-2020, 10:15 AM | #6 |
Rep 242
Hi,
I had the same problem (but with uniscan) and I solve - thanks to BimmerCode support - so: - engine running - click 3 times start button to enter in the diagnostic mode - now try to connect with bimmer app Ps make sure that u disconnect Bluetooth phone from car (https://bimmercode.app/quick-start-guide/) On the site vepeek is no more compatible Bye Francesco |
03-18-2020, 06:48 PM | #7 |
Rep 25
You will not be able to access everything in Bimmercode without the approved adapters. I too reached out to Stephan who is the developer and until I got the Ethernet and lightning adapter I was not a able to program sport + and a few other items with my veepeak. Again this is just tied to G20s
