2.5" vs 3" chargepipe
03-15-2020, 08:08 AM | #1 |
Rep 167
Hey gang, I have a Stett chargepipe with meth bungs that is approx 2.5" diameter piping. I've been searching for my answer and can't seem to find the answer. Is there a dramatic difference between a 2.5" and 3" chargepipe?
I have a 3" from before when my turbos went tits up, but it had a slight worn spot so went with a new one. I believe I read that a 3" minutely introduces more lag but increases power? Is it worth the swap out? Thanks and sorry if I totally missed other threads regarding. |
03-15-2020, 02:55 PM | #2 |
Rep 2,020
What sizes are the pipes leading to the cp? Starting from the outlets, fmic in, fmic out, j pipe ....cp.
it will only be a benefit if there is any significant pressure drop across the cp. i can calculate that if you have an estimated Maf or power since the charge is cooled and boosted as it enters the cp, it sees the lowest volume flow rate and lowest pr drop. So unlikely any benefit. Worst pr drop would be the hot air going thru the outlets, although we have two of those so needs to be doubled. Fmic out, j pipe and cp see the lowest cfm.
335i e92 TPC 19Ts
03-15-2020, 06:38 PM | #4 |
Rep 167
Yikes, ok, so here is the mod list.....
RB Turbo Servicing including new bearings, seals, thrust upgrade, vsr balancing, upgrade to 15T Billet Compressor Wheel/Bullet nut, wastegate servicing and/or adjustment, Upgrade to RB Next Gen (add TD04L-11 blade turbine) RB High Flow Silicone OEM Style Inlets RB High Flow Oil Drains RB Basic Install Gasket Kit RB PCV Valve RB PCV Screw-On Cap New Bosch Alternator Boost Concepts FPM-1 Plug-n-Play 135i 335i N54 E85 Fuel Pump Bucket LPFP STETT Performance N54 335i Dual Diverter Valve Charge Pipe STETT Performance N54 335i Stainless Vacuum Canisters DCI BMS Cowl Filters N54 JB4 MHD BEF Trebila tune N54 BT Connect kit N54 3.5bar TMAP sensor FSB controller 100% methanol injection Dual CM10 Methanol Injector Nozzles BMS Oil Catch Can UUC Black Transmission mounts Engine Mounts Methanol AR 3” catless downpipes Forge Diverter Valves Helix Intercooler Clutch Delay Valve Clutchmasters Single Mass Flywheel and Clutch TC Kline suspension Powerflex subframe bushings Powerflex differential bushings Think that is everything..... I'm guessing I'm somewhere between 480rwhp and 510 rwhp. |
03-15-2020, 08:22 PM | #5 |
Rep 532
Id venture to say you **might** pick up 5whp with larger charge piping. I was eluding to a 800whp big turbo build where you might see something more like 25whp.
