Closest sounding f1/v12/high-pitch exhaust?
03-18-2020, 04:54 PM | #1 |
Rep 101
335i 2007 n54: Hey yall its my first post and Regardless of how many times people have asked this i want new opinions on what the title says: what exhaust has the closest sound to f1/v12/high-pitch sound. Before you say "it's impossible because etc" I know its a 6 cyclinder but there has to be something more high pitch than the rest. Not looking into straight pipe but more so a custom exhaust or aftermarket exhaust regardless if its illegal where I am in California.
Drop some suggestions id really appreciate and will reply back thankyou! |
03-18-2020, 05:09 PM | #2 |
Rep 3,926
WTF? Are you 12??
The pitch of the sound is a product of the number of cylinders, the rpm (and whether it's 2/4stroke etc)...no exhaust will change that. Only options are to raise the rev limiter (a lot), or add more cylinders. Good luck with either of those! |
03-18-2020, 05:13 PM | #3 |
Rep 101
Like I said "I know its not 12 cylinders" i want to know whats the Closest sounding exhaust to the high pitch of a 12 cylinder no matter How far off it is lol thanks
03-18-2020, 05:18 PM | #4 |
Rep 3,926
Did you read my whole reply? The exhaust doesn't change the pitch of the sound. End of. The scream of older f1 cars that you're referring to is caused by engines with many cylinders revving very high. Neither of which is attainable to you.
Over and out. |
JC_AD335i27.50 |
03-18-2020, 05:20 PM | #5 | |
Rep 947
Drives: e92 335i, f22 m235i, e30 325is
Would be nice though, thats for sure |
JC_AD335i27.50 |
03-18-2020, 05:25 PM | #6 |
Chelsea Football Club
345
Rep 780
Downpipes and straight piped. Drive a manual or manual shift mode, get xHP stage 2 minimum so the auto-trans doesn't auto shift, and drive in the mid to high rev range. Car turns heads and sounds as close as its going to get to an F1 sound.
It's when these cars drives in the low range that you get that annoying coughing rasp sound. |
03-18-2020, 05:26 PM | #7 |
Rep 101
Yes of course i read your reply man but i already know its not a v12 and at the same time there are exhausts that sound either deeper, high pitched, quiet, etc with different exhausts setups, so actually the exhaust does do something with the pitch noise or tone lol we both know this already and you know what im trying to ask dont give a hard time man but thankyou for your responses!
03-18-2020, 05:30 PM | #8 | |
Rep 101
03-18-2020, 05:40 PM | #9 |
Rep 2,758
You need kittyless dp to get any type of loud/high pitched sounding exhaust. My kittyless dp and Eisenmann Race exhaust is pretty high pitched when winding it out.
03-18-2020, 05:48 PM | #10 | ||
Rep 947
But, OP he is right about needing catless for higher pitch. Our cars have 2 cats and a muffler. And a resonator if you have an e90. You should be okay with just a primary cat removal. You will still fail smog though, so you can either install a DP fix, or pay a lil extra to pass |
03-18-2020, 05:53 PM | #11 | |||
Rep 101
03-18-2020, 05:56 PM | #12 |
Rep 101
I will definitely get kittyless downpipes haha and yess ive heard that exhaust in videos but it sounds a bit deep but then again im sure your right about high pitched, do you have videos of it? and how loud is it compared to stock?
03-18-2020, 06:35 PM | #13 |
Rep 532
Twin Turbo N54s typically sound like shit compared to other platforms. If you go catless and straight piped your car will sound like a clapped out Civic at anything other than full throttle.
You are much better looking at options that include resonators/mufflers for a better all around sound. |
JC_AD335i27.50 |
03-18-2020, 07:00 PM | #14 | |
Rep 101
03-18-2020, 07:17 PM | #15 |
Rep 2,758
The Eisenmann Race has a deep rumble when cruising and in low RPM's, but when you're WOT it's much more high pitched. I don't have any videos, I have tried but they don't sound very good since I don't have an external mic. It is pretty loud compared to stock, especially at cruising rpm's before the engine/exhaust is warm.
JC_AD335i27.50 |
03-18-2020, 07:23 PM | #16 | |
Rep 101
Also I saw a video of Vrsf exhaust with a resonator put into it and it sounds mean but i cant tell how loud it is. Heres the link to that |
03-18-2020, 07:26 PM | #17 |
Rep 2,758
The Eisenmann Race axle back? It's legal, as long as your car is muffled it's legal in CA, unless you mean from a db level point of view then no. But I have had this setup for years now and even when the CA exhaust sound level thing blew up at the beginning of last year I never had a cop pull me over for it.
03-18-2020, 08:27 PM | #18 | |
Rep 101
03-18-2020, 08:40 PM | #19 | |
Rep 947
Eisenmann was the original e9x exhaust system I fell in love with when the 335i first came out. Lately I've been looking to do the DIY PE mod using my stock mufflers as well as a primary cat delete |
JC_AD335i27.50 |
03-18-2020, 08:58 PM | #20 | ||
Rep 101
03-18-2020, 09:32 PM | #21 |
Rep 86
The N54 wirh stock Turbos sounds like crap regardless.
Antetokounmpo1551.50 JC_AD335i27.50 |
03-18-2020, 09:32 PM | #22 |
Rep 2,758
The Eisenmann race version is practically straight through mufflers. The way the piping is it goes straight through the muffler and out into the tips, with openings to divert some sound waves through the actual "muffler" but pretty much almost straight pipes. I think that video is either the sport version or they have catted down pipes on the car.
