BMS BOV Adapter
03-21-2020, 01:54 PM | #1 |
Rep 35
BMS BOV Adapter
I am installing a VRSF charge pipe and purchased the BMS Bov Adapter for the larger hose. How in the hell do I get this clip off? I don't want to break it and haven't had any luck turning or squeezing it to pull it off.
View post on imgur.com |
03-21-2020, 06:35 PM | #2 |
2007 335xi
31
Rep 69
look at arrows and push in firm both at same time and pull it out pita to push
2007 335xi Daw stage 2 old wheel custom 2.25 relocation inlets vrsf alum outlets.Vrsf 5'' stepped intercooler.stage 2 bucket lpfp.BQ tune xhp stage 3 tranny flash.vrsf downpipes modified 3in exhaust.ER charge pipe tial bov.Custom oil cooler..cic retrofit.koni shocks h@r sport spring staggered conti tir
CountDracula10.00 |
03-21-2020, 06:38 PM | #3 |
2007 335xi
31
Rep 69
here is pic not uploading right and to clarify cuz I don't explain good ..figured only tabs you can push in ..you can see are on top and bottom blue arrows as you push as hard as can on blue arrow on top and bottom then where red arrows are you will see spread when happens full strait out
CountDracula10.00 |
03-22-2020, 03:42 AM | #4 |
Rep 713
I would have thought that you have to push at the opposite of the arrows of your pic. I would push on the small tabs (with dashes/lines) there is another that is behind and can't be seen on the pic.
This is how i push on the brakebooster line connector at the vacuum pump which is the same connector (when disassembling airbox for example).
beter laat dan nooit
