03-22-2020, 07:09 PM | #1 |
Rep 2,015
Quick Question on Valve Cover Replacement
So I am about to replace my VC. seen enough videos.
Dealer advised that there is a Crack in it at the back. Questions: 1) When removing the Fuel Lines, what Sizes Open End Wrench do I need? I heard there were 2 different Sizes. 2) Can I get the Torque Values of all the Bolts? please. Thanks in advance. |
03-23-2020, 02:59 AM | #3 |
Rep 2,015
Thanks you very Much.
What does Strut Bar Center Read? 56nm/41ft-lbs +90 degree. Did I read that right?, why would not just add the appropriate Torque Level? Also Just curious why is some Crossed out and re-written by hand? Just Curious, not trying to pick on it. Thank you again very Much. |
03-23-2020, 10:24 AM | #5 | |
Rep 1,827
This is typical of stretch bolt torque specs. Because they "stretch", they don't torque linearly. Likely, they would stretch after the 41 ft/lb mark and you wouldn't be able to get your torque wrench to register much higher, you'd probably just end up stripping the bolt.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
BashShah300.50 |
