03-23-2020, 06:34 PM | #1 |
Rep 49
M2C on lowering springs/coilovers with after market wheels
hey guys I have a 2019 m2c that I am trying to lower but I have 20" wheels (20x10 and 20x9). does anybody know my best route for lowering? coil overs? lowering springs? what do you guys recommend?
04-28-2020, 03:10 PM | #2 |
Rep 923
there is no good answer to this question.
first what are the offset of your wheels ? because you have the same width as oem so there is no problem here unless you have very agressive offset. for suspension, depend of you goal and budget, you can spend on some f82 m4 swift spec r lowering spring. in my mind thay are amazing but will def lower the shock life . then you can put bilstein b6 sport shock to replace oem shock. you can go with any has, like dinan or kw….. you will blow you oem shock faster like the swift….. you can go cheap coilover like bc racing (would never do that) bilstein pss10 good comfort and perfromance kw v3 bilstein pss10 rival etc etc ohlins mcs …..just depend how much you want to spend |
04-28-2020, 04:09 PM | #3 |
Rep 4,145
Drives: '18 M2 6MT
To get a good answer to this question you need to post your goals. Just saying you want to lower the car isn't nearly enough information.
We need: Make/Model and exact spec + offset of wheels. Make/Model and exact spec of your tires. How low are you wanting to go? What's your budget? Are you wanting larger tires? Would you consider skinnier tires? How important is ride quality to you? Do you ever track your car? Do you have good streets or are they full of pot-holes? I mean, you need to give people good information if you're looking for good results. |
Kankles1485.50 |
