03-26-2020, 04:27 PM | #1 |
Rep 2,700
I am installing my Ohlins kit with custom spring rates, here is my question.
Normal spring rate for onlins is 90nm front and 190nm rear. I have 70nm front and 140nm rear. Is there a way to calculate how much more preload I need to end up at the same ride height than with the original spring rates ? Per instructions at the rear I need 40mm of space between top spring lock nut and body seat. In the front it's really 5mm of preload - Also why is the onlins rear shock lenght instructions so short, they say they need to be at 500mm and the OEM shock is like 600mm, that's like 4.5 inches less of full droop ?? thank you
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
03-29-2020, 04:11 AM | #2 |
Rep 1,271
Well this is a very good question. How does it ride on Ohlins, I am about to get a set myself.
I suppose there are two versions of it. One track focused and another for road. So I suspect you may have the road version. As far as preload etc, I take my cars to a specialist that corner balances and aligns my car. It's for the best. |
03-29-2020, 09:06 AM | #3 | |
Rep 2,700
I'll report back on the ride
04-01-2020, 02:25 AM | #4 | |
Rep 557
I'm planning to install mine tomorrow, I have springs in between, 78Nm front & 160Nm rear. I'd like to stay stock height or maybe 5mm lower, want to keep compression travel especially in the rear. |
04-01-2020, 12:32 PM | #5 |
Rep 3,549
The preload's function is to make sure the spring stays seated under full droop and doesn't come loose. I'd imagine 5mm with the different spring rates is still fine.
If you're really worried about it you can calculate how much force the stock spring rates make at 5mm of compression and then calculate how much compression you need from the new springs to make the same force and set that as your preload. For the rear, the spacing they recommend is to give the damper piston sufficient margin for travel under driving conditions so it doesn't hit either end. To compare ride height differences between the springs you'll need the corner weights of the car. You already have the spring rates.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-01-2020, 02:06 PM | #6 |
Rep 2,700
Alright guys, I got some time to work on the car and here is what I've been trough.
First of all what I did not realise from the start is that the 140nm swift rear springs that Ohlins sent me were 230mm long instead of the 190nm 200mm ones that come in the original kit and that the instructions are based on. This is basically the same difference between the original M3/M4 kit and M2 kit wich explains the preload difference (40mm vs 10mm) I realised this after dropping the car at 40mm preload, the rear was like 1.5inch higher than stock specs I then proceeded to drop the preload to 10mm wich required unbolting shock and control arm. This gave me a ride height around 10mm lower than the instructions and even lower than the front. I then managed to lower the adjuster (more prelaod) 5mm without unbolting everything wich is NOT easy because of the lack of space and the tedency for the seat to spin. I have to go out now to find some flat places to re-measure the ride and decide were I want to finalise my adjustments. This could be made much easier and a lot faster on an alignment plaform and I DO own a lift.. (my floor is sadly not flat) Surprisingly following the instructions the front ended up exaclty 10mm lower than stock. I have not decided but may remove a max of 5mm of height wich I will try to do with the spring preload to not lose any travel. I have found the best method to measure height and make adjustment is the oem one. See picture attached, this helped me because my car was not stock and had Dinan HAS already installed and I had no idea of my stock ride height. Here is also the OEM specs: AFAIK, F87 M2 OEM stock ride height (OEM suspension, wheels, tires, tire-pressure and of course without shipping blocks): front wheels: 612mm ("series") and 622mm ("bad-road package") (see here); rear wheels: 615mm ("series" + "bad-road package") (see here).
04-01-2020, 02:13 PM | #7 | |
Rep 2,700
See my above post for the fronts, I set everything up per instructions and ended up 10mm lower like they supposed to.
David.m449.00 |
04-01-2020, 09:43 PM | #8 |
Rep 303
Before finishing up.....suggest you check your rear shock travel and make sure your not on the bump stop (pinch the bellows to check the space between the shock body and top of the bump stop).
The rear shock body on the R&Ts may be a bit too long for the F8x chassis, and can be problematic if car is lowered too much. |
04-02-2020, 06:50 AM | #9 | |
Rep 557
04-02-2020, 07:07 AM | #10 | |
Rep 557
04-02-2020, 07:35 AM | #11 | ||
Rep 2,700
04-02-2020, 11:25 AM | #12 |
Rep 303
I believe the 500mm per set-up instructions is where you want to be. My suggestion was to be careful in lowering rear ride height beyond Ohlins specs (using the spring perches...which is a separate issue altogether), to be sure you’re not on (or near) the shock bump stop.
04-02-2020, 12:37 PM | #13 | ||
Rep 2,700
04-09-2020, 04:35 AM | #14 | |
Rep 557
Using a piece of A3 paper between the tyre tread & guard lining (because you can't see in there) I worked out setting my shock length at 520 gives me 4-5mm clearance (ie the 285/35/19 PS4s touches the guard lining with shock at 515mm). I still have more compression travel than the oem shock allows and a lot more travel before initial contact with the bump stop compared with stock. Had my alignment done today and went for a 1/2hr drive on roads I travel daily and the improvement in compliance (if that's the right term) is significant. It's still as stiff/firm as oem (maybe even firmer) but the dramatic rebound is gone, and whereas before a road with varying smaller undulations would have you bouncing around you now feel the bumps but pretty much stay in your seat. Very happy |
04-09-2020, 07:38 AM | #15 | ||
Rep 2,700
My alignment is still not done and I'm riding on beat up Cup2 tires wich have a very stiff carcass and seem to get noisier and maybe even stiffer as they have less thread on them but I have to keep in mind we have some of the worst roads, you wouldn't believe it. I am hoping switching to brand new PS4s will improve the ride and lessen the metallic bang you ear/feel at the front with the camber plates. As of now I tried setting the clicks to 15, 18, 20 and to like 30 wich did not make much difference from 20. What clicks have you tried ?
04-10-2020, 03:48 AM | #16 |
Rep 557
So far only 18 clicks, corona 19 restrictions here means driving only to work or to shops for food. Pre install my main concern was it being too stiff as my wife has had spinal fusion and doesn't like riding in the M2 so I was hoping (though not expecting) a smoother ride on the soft setting. So I'm both surprised and very happy with the outcome, the poor surface on some local roads even caused M2 occupants to be thrown side to side, really not good for her back, but now you feel the bumps but don't get thrown around.
PLF693771.50 |
