N54 Tial BOV vacuum line
04-08-2020, 11:12 AM | #1 |
Rep 102
2008 335xi
Installing ARM charge pipe and TiAL BOV The BOV comes with a pretty large vacuum hose. I thought it would connect to the factory spot by the throttle body where the factory vacuum line was for the 2 diverter valves was, but that is too small. Where is the best place to connect the BOV vacuum line? Second question: where the metal fitting is in the top of the BOV for the vacuum line, it's extremely loose, how tight do I have to tighten that to make it seal?
08 335xi
C6 Z06 |
04-08-2020, 12:31 PM | #2 |
Rep 304
I used a vacuum fitting adapter to go from the smaller 3.5mm vacuum line to the larger line. Seems to work just fine for me.
And just tighten the fitting down as tight as feels comfortable. There is probably some sort of torque spec somewhere, but keep in mind there should be a crush washer to seal properly. |
04-08-2020, 12:36 PM | #3 |
Rep 823
Many have had issues with the BOV opening properly after trying to use the factory vacuum nipple on the manifold. I plugged that one and installed a 1/4" nipple next to it that I picked up at the local hardware store.
04-08-2020, 01:37 PM | #4 | |
Rep 102
Right?
08 335xi
C6 Z06 |
04-08-2020, 08:26 PM | #6 |
Rep 2
https://burgertuning.com/products/bm...vacuum-adapter
or https://vadersolution.com/collection...v-line-adapter Heard that the wait for the Vader Solution's one can be a while. Both convert to 1/4 line which is what Tial recommends |
04-09-2020, 07:01 AM | #7 | |
Rep 3,732
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
faithkharkov27.50 |
04-14-2020, 08:12 AM | #8 |
Rep 102
Exactly what I ordered, so hopefully in a few weeks it'll arrive over here and I can put it on, along with their upgraded PCV too
08 335xi
C6 Z06 |
