04-08-2020, 08:21 PM | #1 |
Rep 16
Sucked mf paper towel into my turbo inlet pipe.
Ok so I’m an actual retard.
I had my intake off painting it, I stuffed paper towel into one end to stop paint from getting inside. I forgot to remove the paper towel and I put my intake back on. Started my car up and obviously it sucked it in instantly. Wondering if anyone else has had something like this happen and what is best/ worst case scenario? How would any of you handle this situation? I plan on removing my inlet pipe and see where this damn paper towel went and/or if it got shredded. Thanks guys any input is appreciated. |
04-08-2020, 09:05 PM | #4 |
Rep 7,632
Sorry but i LOL when i read this. Was it just one paper towel or a whole clump? Normal PT or like the blue heavy duty ones?
If its just one normal PT i doubt it was strong enough to cause any damage to the turbo, especially since it probably got sucked in right at startup (before turbo was spinning fast). Most likely it got shredded by the turbo; pull the inlet to confirm. If you can find anything on the pre-turbo side, consider dropping the IC and taking a look. Whatever made it past the turbo will likely be stuck in the IC fins. You can blow backwards through the IC with a blower or compressed air to force anything out. The good news is that the IC should block any big "chunks" from making it further into the engine where they might go into vacuum lines or something else. |
04-08-2020, 09:13 PM | #5 |
Rep 16
Thanks so much for the reply man. I don’t blame you for laughing. Seriously stupid and childish mistake on my part 🤦*♂️. It was a decent clump, probably about 3 in Total, just normal white paper towel not the heavy duty blue ones. I stuck my vacuum as far down the inlet and didn’t suck anything out so I’m guessing it’s all been shredded.
Cars in my driveway so I’ll have to wait until morning to jack it up and take the inlet off. what do you think about what peter said? Any chance it could just get burnt up and blown out my exhaust? |
04-08-2020, 09:22 PM | #6 | |
Rep 7,632
Most likely you have nothing to worry about. The main concern is if they get past the IC and into any small vacuum lines or passages. |
04-08-2020, 09:33 PM | #7 |
Rep 16
I put the intake back on, started my car, ( it had a fully gutted exhaust and it sounded WAY louder than I’ve ever heard it, rough idle, then it threw a drivetrain malfunction code, I was moving my car for my dad so I had to reverse down my driveway then back into drive to park my car up. All In all was probably running for 30 seconds but I never really gave it any throttle.
So basically all I can really do is pull the inlet and intercooler clean them out as best as I can and hope It’s all good lol? |
04-08-2020, 09:40 PM | #8 | |
Rep 7,632
04-08-2020, 09:51 PM | #9 |
Rep 16
Ok. I’m quite the noob when it comes to the N55, are the pressure sensor and MAP you’re talking about the two connections on the driver side charge pipe? Or on the turbo to intercooler charge pipe? If that makes sense.
Thanks a lot for the replies too dude you’re making me feel a little better about my situation lol. |
04-08-2020, 10:47 PM | #10 |
Rep 7,632
Theres nothing on the turbo to IC CP. There is one pressure sensor on the CP right before the throttle body (this is where you get pre-throttle boost from in logs) and another after the TB in the intake manifold (MAP in the logs).
04-08-2020, 11:18 PM | #11 |
Rep 16
Ok ok gotcha, so let’s just say I take all the stuff off but don’t find all the paper towel, is it likely there could be some stuck right inside the turbo? What about starting the car to force the remaining PT out of the turbo down to the IC? Does that make sense or should I not start the car until I’ve cleaned as much out as I can?. Sorry for the beginner questions, this is just an unprecedented situation for me and I’m pretty new to bmws and cars in general but trying to learn.
04-08-2020, 11:47 PM | #12 |
Rep 7,632
I think you are overthinking it at this point. You already said you verified the turbo. Confirm there is nothing stick in there by looking through the inlet or the TIC pipe. Then check the IC, and you can always just pop the CP off the TB real quick as well since that is easy. Just have a look around and report back.
04-09-2020, 01:52 AM | #13 | |
Rep 790
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-09-2020, 08:33 AM | #14 |
Rep 1,499
Honestly, I would start by removing the CP at the throttle body. If you see shreds of PT there then you need to remove everything downstream and clean it out real good. If you see shreds in the CP and want to go the extra step remove the manifold and check it for debris/clean it out. If you don't see shreds in the CP then move on to the FMIC by checking at the outlet connection at the CP, if nothing there keep moving backward checking at each connection.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
harkes1091.50 |
04-09-2020, 11:33 AM | #15 | ||
Rep 7,632
04-09-2020, 01:49 PM | #16 |
Rep 16
Ok guys so I think I got really lucky here. But not out of the woods yet. i first took off my Turbo inlet, most of the PT was stuck in there. Almost the full clump, it’s about a 3.5 foot long section of PT lol. I un crumpled it and in total about a Kleenex size amount of PT got shredded by the turbo. I moved the turbine blades slightly with my finger and is spinning fine and I don’t feel any play. Been trying for a couple hrs to get my Turbo to IC charge pipe off to check the IC but I really don’t wanna break the tab on the back, I don’t remember my VRSF CP install being this difficult 🧐
04-09-2020, 01:54 PM | #18 | |
Rep 7,632
When you dropped the IC, were any of the "missing" pieces in the IC fins (on the hot side toward the turbo)? |
04-09-2020, 04:54 PM | #19 |
Rep 16
I haven’t checked there yet no, But don’t I need to remove the TIC pipe to drop the IC? it’s currently snowing where I am so I won’t be able to wrench on it again until tomorrow. My exposed engine bay got pretty wet from the snow already lol
04-09-2020, 05:46 PM | #20 |
Rep 7,632
No, you dont. Dropping the IC is quick. Just take the 15-20 8mm bolts off that hold the undertray on (recommend an electric tool so this takes 2 minutes instead of 20), remove the clips that hold the TIC and CP onto the IC (one on each side), take off the 2 bolts that hold the IC onto the car (one on each side of IC), and the IC will fall down. You can leave the TIC and CP in place.
04-10-2020, 11:12 AM | #21 |
Rep 440
Drives: 2013 335i xDrive
Cleaning the intercooler should be very easy. Take off both pipes, squirt a little starter fluid into the outlet of the intercooler and light it. If there is any paper in there it will come out. Or you could just use a leafblower or vacuum cleaner, your choice. But starter fluid makes a cooler story.
I'm kidding, don't use starter fluid. Use a vacuum cleaner on the inlet side.
I'm not completely useless, I can be used as a bad example.
