04-09-2020, 03:22 AM | #1 |
Rep 36
Coding directory
Hi guys!
Im fresh man in this forum but i would appreciate that somebody unlocked the sport plus mode. Its really good and i feel difference. Whats more, i have a question, is there some “library’s coding” which functions can be coded in our g20/g21? We have a lot of topics on this area but I couldn’t find a summary of what has been unlocked? BimmerCode website I think isn’t updated. What do you think? It will be a good place for everyone and we can encourage new members to our forum because list of coding will be clearly and in one place. It can be update from time to time “ edit function” .Thanks in advance! |
04-09-2020, 05:28 AM | #2 | |
Rep 325
Sport+ is here, check it out: https://www.bimmerpost.com/forums/sh....php?t=1697654 |
04-09-2020, 05:38 AM | #3 | |
Rep 36
04-11-2020, 01:52 PM | #4 |
Rep 243
Yeah there's loads of stuff for the F-series but hardly anything for G-series. *********Database is only showing E&F and most of the tutorials are not updated yet. Any help would be great please!
EDIT- Don't know why the forum replaced BMW and Coding before database with stars lol |
04-12-2020, 07:16 AM | #5 |
Tanzanite
9
Rep 25
Drives: 2019 BMW 330i xdrive G20
Bimmercode
New comer to coding. I'm am using the OBDLINK MX+ bluetooth adapter paired with BIMMERCODE
I have recently use BIMMERCODE to code my g20 series an didn't hav much luck with searching every website that could think of an looking at cheats sheets for coding. I have only unlocked: M startup display 5 flashes of the turn signal video in motion Sport+ Comfort+ Daytime running lights on/off function Also had the M live cockpit as my gauge cluster looked really good, but it did not allow for the gauges to really change colour when in sport, comfort or eco mode, the biggest issue with the M sport gauges is that is does NOT show when you are in Sport+ mode or Comfort+. I ended up changing it back to the original load out. Also tried to use E-sys cheat sheets to try an decipher BIMMERCODE with no luck... Will continue to research hoping to find: Automatic Heated steer wheel Reverse camera zoom Ambient lighting colour change (other than what factory allows) |
04-12-2020, 10:38 AM | #6 | |
Rep 44
g20beam figured out the auto steering wheel heating already. I can't find his post however. He has also found some other cool things in expert mode. I highly suggest following him on here as his coding tidbits are great
g20beam477.50 |
04-12-2020, 12:19 PM | #7 | |
Rep 36
Short list with coding functions. Is there possible to code other video formats in idrive 7 in bimmercode? |
04-13-2020, 11:16 AM | #8 | |
936
Rep 4,327
Drives: M340
https://g20.bimmerpost.com/forums/sh...0&postcount=13
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
04-15-2020, 08:53 AM | #10 |
Tanzanite
9
Rep 25
Success with coding with everything but the automatic heated steering wheel I have tried a few different ways but can't get it to load up in the idrive might be because I can't access the MGU-head unit in expert mode, I have emailed BIMMERCODE just waiting to hear back from them if I can be a beta tester.
04-16-2020, 04:02 AM | #11 | |
Rep 48
04-16-2020, 09:41 AM | #12 |
Rep 1,496
I am also interested in the full SMS display
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i | |
04-17-2020, 04:08 PM | #13 | ||
Tanzanite
9
Rep 25
04-18-2020, 03:55 AM | #14 |
Rep 48
Heated seat coding works properly? I coded that but it did not work properly. I could not be able to change the levels of the passenger seat at all (from the settings menu). And for the drivers seat, I don't remember exactly -I think it was keep sticking at the middle- but it was not working properly as well.
