Cons of XHP?
04-14-2020, 02:42 AM | #1 |
Rep 117
Cons of XHP?
Hey guys, i'm looking into flashing my n54 to stage 3 xhp but I haven't seen anywhere on pre maintenance before flashing it. Is there anything I need to do before I flash it? & also when I flash it is there any down sides to it? will it kill my transmission sooner or extend it?
(FYI FBO 335i) |
04-14-2020, 10:04 AM | #2 |
Rep 1,667
As long as you have a post 03/07 build it will make all of your wildest dreams come true according to this thread...
https://www.e90post.com/forums/showthread.php?t=1708294 I have a pre 03/07 build...and i've been running stage 2. IMO it's kinda meh. I've got 96k miles and been tuned with it for 4 k miles or so. I did quite a bit of searching before I installed and I didn't find any evidence of people saying it resulted in less reliability. I didn't do any extra maintenance before I installed. My trans had a new filter and fluid flush at 80k miles. |
Adrianizzle38.00 |
04-14-2020, 10:11 AM | #3 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
In order to get 3.0 for pre-03/07 cars, you need to either wait until they update (they might not) or change out the TCU to a post 03/07. You can easily do this when changing out the solenoids etc. Hard part might be finding one for a reasonable price. Coding it won't be difficult. |
04-14-2020, 10:21 AM | #4 | |
Rep 117
04-14-2020, 11:55 AM | #6 |
Rep 117
04-14-2020, 12:36 PM | #7 |
Rep 1,245
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
04-14-2020, 07:17 PM | #8 |
Rep 6,968
Yes
04-15-2020, 11:01 AM | #12 |
Rep 1,200
Supposedly will decrease life of physical components in the transmission. Wouldn't be a bad idea to do a service
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
04-16-2020, 07:01 AM | #13 | |
Rep 3,731
But...like everyone else said. Replace the seals while you are in there. More pressure + worn/cracked seals = more problems .
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
Adrianizzle38.00 |
04-16-2020, 12:47 PM | #14 | |
Rep 4,325
My transmission shifts smooth through all the gears but I would like it to shift faster with the paddles. I read a while ago the shifts were supposed to be similar to that of an smg. |
04-16-2020, 12:54 PM | #15 | ||
Rep 947
Drives: e92 335i, f22 m235i, e30 325is
I made some very minor tweaks to the shift speed settings, but more or less default OTS. Last shift isnt as crisp because I had to ease off while hitting the paddle after someone switched lanes in front of me Quote:
FCP euro sells the kit ready. also...I hope you fixed your o2 sensors from that old post before modding your car more Last edited by ky0u; 04-16-2020 at 01:03 PM.. |
Adrianizzle38.00 |
04-16-2020, 04:54 PM | #17 |
Rep 947
04-16-2020, 05:05 PM | #18 |
Rep 1,245
Can't judge it off of part throttle shifts. It's not until wide open that xhp slows the shifts down and pulls a bunch of timing between gears.
If it could shift as fast as it does part throttle at wot, I'd have almost no issue with the tune. As it is, you need a a Sutphin custom tune to take full advantage of the transmission.
04-16-2020, 05:15 PM | #19 | |
Rep 2,758
04-16-2020, 05:33 PM | #20 | ||
Rep 1,245
..lol
04-16-2020, 05:37 PM | #21 | |
Rep 947
I'm familiar with your huge thread here and on SS. I also recall someone likening it to a CVT, but if those crisp shifts are the behaviour you're seeing with Sutphin, it honestly seems closer to DCT |
