04-15-2020, 06:38 PM | #1 |
Primo Generalissimo
5073
Rep 4,217
Drives: All of them
Garage List 2024 Ford Bronco Ra ... [10.00]
2018 Porsche 911 GTS [10.00] 2023 BMW M2 [9.25] 2022 Ford F-250 Tremor [8.50] |
PCs
What PC configs work best? Would an intel NUC like a Hades Canyon be up to the task?
04-15-2020, 07:12 PM | #2 |
Rep 911
Drives: 2024 BMW 230i xDrive
If you are talking a PC primarily being used for sim racing purposes you do not need anything special.
Go look at the system requirements for iRacing or Assetto Corsa and you will see that pretty much any computer from the last 5-10 years will work just fine. I picked up a used PC (with an AMD A8-5500) for under $300 that I'm using and it's running Assetto Corsa with ease. That said, I'm not a gamer, so if you plan to use it for other gaming purposes don't bother listening to me
This post sent using 100% recycled electrons.
04-15-2020, 10:45 PM | #3 |
Rep 465
Drives: E46 M3 / E92 M3
Check out https://pcpartpicker.com/ as they have custom builds documented. Seems like you can build a solid overall gaming rig for around $800 using the AMD Ryzen 5 CPU and a AMD RX 580 video card.
Check out these builds for under $800. https://pcpartpicker.com/builds/#X=0,80905&s=33
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3 [Tow/Overland] 23 Toyota Tundra HV TRD Off-Road |
04-15-2020, 11:04 PM | #4 |
Rep 440
Drives: 2013 335i xDrive
A NUC mini PC is a good idea on paper but has heat issues. I7 processor + passive cooling + small space = trouble. We had three of them at work and had to remove all of them because of overheating and freezing the video output during Zoom presentations. They were the sixth generation that supposedly have a "fix" for overheating. I've got one on my desk, it makes a nice paperweight. The skull on top is a nice touch.
I'm not completely useless, I can be used as a bad example.
04-16-2020, 04:04 PM | #5 | |
Primo Generalissimo
5073
Rep 4,217
Drives: All of them
04-16-2020, 04:39 PM | #6 |
Rep 440
They work well for firewalls. Mine is running Ubuntu 18.04 server and works great. Less than a hundred dollars for a fully hardened and capable firewall is not bad. I wouldn't use it for a PC because the graphics are weak.
I have one of those Lenovo m720 Tiny small form factor desktops with I7 processor, 16 GB ram, 1TB M.2 SSD hard drive I use for a Windows deployment server. Works great, fast, stable. It's very similar to this: https://www.ebay.com/itm/Lenovo-Thin...UAAOSwsEteZnzo
04-16-2020, 06:17 PM | #7 | |
Primo Generalissimo
5073
Rep 4,217
Drives: All of them
04-16-2020, 07:04 PM | #8 |
Rep 440
Oh, fooey. I missed the part about using it strictly for sim racing. Yeah, pretty much anything with decent RX580-ish specs will work.
04-26-2020, 03:27 PM | #9 | |
Rep 2,539
Im running an RTX 2080S and can hit 100fps or so on 3 x 1440p monitors with high/ultra settings in most titles. ACC takes the most graphics power, iRacing the least. So YMMV depending on what your expectations are and setup. |
