M3 control arms kit
04-15-2020, 08:35 PM | #1 |
i do not have a title
75
Rep 308
Drives: e92 335i, f82 M4
M3 control arms kit
Hi, I've been looking at improving the handling of my 335i and was thinking about getting some m3 control arms; there seems to be lots of kits online with varying amounts of pieces; how big of a difference would say a 4 piece kit vs 20 piece kit make? Cheers!
04-15-2020, 09:28 PM | #2 |
Rep 3,732
The only thing that makes a difference in hanging are the actual M3 control arms. Some of the kits come with more "extra" parts like ball joints, bushings, tie rod ends...etc,etc...
04-17-2020, 10:45 AM | #3 | |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
The M3 arms are probably the worst bang for your buck suspension wise. The fronts make a difference the rears much less. Then to really get the advantages you need to replace all the rubber bushings front and rear with balljoints, in my opinion. One of the last mods I would do to a E9X suspension. If you go with the rear m3 control arms you will then need struts made for an m3 in the rear. This means an off the shelf coilover kit will not work as you need to mix and match E9X front coilovers with rear m3 struts/springs. Not all manufacturers like to split em up. If you do buy m3 arms etc. get the TRW ones with the M logo shaved off and save yourself the $$$. They are the same part. Also, this thread should really be in the suspension section: Suspension | Brakes | Chassis https://www.e90post.com/forums/forumdisplay.php?f=38
04-17-2020, 11:12 AM | #4 |
Rep 3,732
On the front I have the M3 arms in order to give a little more camber. On the rear I have the M3 arms to stiffen things up. This is the same kit from FCP Euro that most people use.......
I also have the hard poly Whiteline rear subframe bushings installed. I also have the Bilstein B12 Pro kit installed with the B8 shocks and the Eibach Sport Springs Not sure I would say it's the"worst bang for the buck" suspension wise......all of those mods have made a big improvement on how the hard handles, and it's gotten rid of the wheel hop on hard launches. |
04-17-2020, 02:28 PM | #5 |
Rep 203
I replaced my front upper and lowers with the m control arms and did new sway bar end links and tie rods at the same time!
That was before I had coilovers and the handling was night and day the little bit of negative camber really helps you keep the car pointed where you want to go especially if side ways! You get much more responsive feedback as well
Crimson LCI E90 N54 auto - sold
Lemans LCI E92 N55 manual - current |
04-17-2020, 02:30 PM | #6 |
Rep 203
How do you like those? I'm getting ready to do my subframe bushing soon, might go with stiff poly ones! Do you get any squeaking from them?
04-17-2020, 03:58 PM | #8 |
Rep 203
Good to know, thanks!
04-17-2020, 06:37 PM | #9 |
Slow.
3782
Rep 7,152
If you are getting subframe bushings there is no NVH from solid aluminum. You have to drop the rear subframe to do the bushings. Do your sway bar(if you want to change it), middle brake lines, diff mounts, etc. At the same time would be my advice.
The rear subframe and diff bushings really firmed up the rear end I found. |
04-17-2020, 06:54 PM | #10 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
04-17-2020, 07:13 PM | #11 | |
Rep 203
04-17-2020, 09:10 PM | #12 | ||
Rep 6,968
You could do M3 subframe & M3 Differential bushings. |
