04-19-2020, 09:38 AM | #1 |
Rep 354
Help with Logs Please
Been opening my logs up in CSV files and reading them that way. Easier to understand but still I'm no expert. Not sure the logs were done right. BM3 auto logging made this 100x easier
DSC completely off. (10sec hold) Manual Gear Selection Started at 2500 3rd Gear: https://www.bootmod3.net/log?id=5e9a...729b04ce73337f 4th Gear: https://www.bootmod3.net/log?id=5e9a...0b43471bdc72bb Any input is greatly appreciated! |
04-19-2020, 11:51 AM | #2 |
Rep 93
What is your engine spec and map?
Ignition is a bit haywire on the 4th gear pull, There's a knock event and a throttle closure . High pressure pump is fine, boost is good vs requested. I think you need better fuel or a bump in Octane/ switch to a 91 map 3rd gear is even weirder |
04-19-2020, 12:01 PM | #3 | |
Rep 354
What could cause a knock? |
04-19-2020, 02:31 PM | #7 |
Rep 354
Oh yea. My bad. I thought the logs indicated i was running stage 2 93oct
I'm FBO. In addition to having a Turbosmart plumb back bov, pure turbo inlet and an Xdi-35 hpfp. Do you think a BMS pedal tuner may cause knock or the weird readings your seeing? I have it on the second pedal sensitivity setting (Green light). |
04-19-2020, 03:12 PM | #8 | |
Rep 7,633
I looked at the 4th gear log and there are numerous throttle closures early on in the pull, likely a result of the overboosting. What BM3 version is this, 7.1? I saw a lot of people having issues like that on the previous versions (after 6.4). IATs also rise to over 100F by the end of the pull, which is surprising if you have an IC. There are also some weird "bumps" in RPM such as right around 6400 rpm. Did you physically hit a bump during the pull? It also looks like you have a lot of timing pulled up top, down to about 6 degrees. I would definitely flash to the 91 octane tune. (Timing is particularly low after the knock, which was likely a result of too much timing for your octane). |
MAKH 588.50 |
04-19-2020, 03:41 PM | #9 | |
Rep 354
Yes. Point of the pedal tuner is exactly that. Completely removes the initial throttle lag and makes the pedal sensitive. Im going to put it on the stock setting and take another log. Currently on BM3 version 7.1. I'll try and log again on 6.4. Also, i do have an intercooler. The turner motorsports black stepped intercooler. Worth noting the 4th gear log was the very last log i took, after about 6-8 attempts. Still weird IAT's would rise so high. Completely overlooked that. I may have hit a bump. Not sure really. I made sure to drive slowly first along the path i would be taking to log making sure to check for rocks, pebbles, random debris etc. (abandoned Air Field). Didn't notice any bumps or major dips in the road. Going to check again when i go back to log. Thought NY pump gas was suppose to be really good. Didn't think i would run into knock issues or timing problems. I did fill up my last tank at a station that probably doesn't get too much traffic and could have poor octane 93. I'll make sure to visit my regular station. Would you advise trying Stage 2 6.4 93 first or straight to 7.1 91. If you can, and don't mind, how does changing to a 91 map on 93 pump gas affect timing? Im a novice. Do you think this is something a custom map would fix? Or should i have better logs first before moving to a custom map/tune? |
04-20-2020, 01:01 PM | #10 | |
Rep 7,633
Yeah might as well try 6.4 if you have it, i think that was the most universally "stable" map before 7.1. It definitely looks like a bump where the wheels lost traction for a second. If you were 6MT i would have been concerned with a slipping clutch or something, but i suspect it was just the road surface. I have seen similar things in my logs, even if it doesnt seem like you lost traction. The order doesnt really matter i dont think, but if you are already on 7.1, just try the 91 7.1 tune. Generally speaking the lower octane maps will run less aggressive timing. So you may not target as high of a timing value of up, but you may end up with cleaner timing overall because you are not targeting more than your fuel can handle, resulting in timing being pulled. Ideally you would get more consistent timing (and this power). I doubt you would feel the difference in butt dyno. It's always fine to run a lower octane map than the octane of your fuel, but you never want to do the opposite. A custom map is always going to be limited by the octane of your fuel, and of course your hardware. You might still be able to make more power with a custom map than a OTS map, but you need to make sure you have no hardware issues first. With a XDI-35, any real gains from a custom tune are only going to be possible if you start mixing ethanol. If you are going to stick with 91/93, the gains from a custom tune over OTS are probably going to be pretty small. EDIT: I would also add that i have found with MHD, i need to drive the car up to 50 miles after changing the tune in order for it to fully "adapt" to the change. This includes having horrible timing right after a flash that cleans up after driving for a bit on the same fuel, etc. |
MAKH 588.50 |
04-20-2020, 01:19 PM | #11 | ||
Rep 354
Did a little research and found exactly what you said. The OTS maps, being that its made for such a broad spectrum of vehicles, probably has really aggressive timing around the higher rpms. May not work the same or be stable for everyones car. For whatever reason, the last the pump gas i filled up with was terrible and I think that contributed a lot. Either way wont be getting gas in the bronx anymore lol. I read BMW DIY Guy was making around 420-440WHP(cary jordan tune) on 93oct which would be more than suitable for me. No E mixes or meth etc. If the stage 2 OTS maps are pushing around 370-380 a custom tune would be a huge jump for me personally. Going to flash Stage 2 7.1 91oct and try logging again. Then maybe 6.4. Edit:I actually re-flashed the car the morning of. Also pushed the car pretty hard before logging. Last edited by MAKH 5; 04-20-2020 at 01:25 PM.. |
04-20-2020, 03:52 PM | #12 | |
Rep 1,105
04-20-2020, 04:21 PM | #13 | |
Rep 7,633
Cool, post up some 7.1 91 and/or 6.4 logs when you have them. 2 good logs of each is sufficient, you don't need to log or do like 4-8 pulls really. He said he has a XDI-35 |
MAKH 588.50 |
04-21-2020, 01:57 AM | #14 | ||
Rep 354
Just saw this in another thread. Im rolling the car to 2500rpm and then flooring it. Also stopped the log 3 seconds after pedal let off. Do you hold the brake while reving to 2500rpm and then floor it? Wish someone made a step by step logging tutorial. Lol. |
04-21-2020, 10:29 AM | #15 | |
Rep 354
https://www.bootmod3.net/log?id=5e9f...90c63d22898a30 6.4 93 OCTANE 4TH GEAR LOG https://www.bootmod3.net/log?id=5e9f...729b4783a9956f So 7.1 is just not compatible with my car. Logs look worse than the 93 if I'm reading them correctly. 6.4 seems to be the sweet spot. At the vey least, no knocks. Timing seems to be good as well. Last edited by MAKH 5; 04-21-2020 at 11:21 AM.. |
04-21-2020, 11:08 AM | #16 | |
Rep 7,633
Also, i would recommend getting virtual dyno and putting these logs in there to see how they compare. It should give you a nice visual representation/comparison of about how much power each is making. Should be pretty accurate assuming these were all done on the same road and similar conditions. |
04-21-2020, 11:24 AM | #17 | |
Rep 354
Guess i'll just drop them here: 7.1 91 OCTANE https://www.bootmod3.net/log?id=5e9f...90c63d22898a30 6.4 93 OCTANE https://www.bootmod3.net/log?id=5e9f...729b4783a9956f i'll check virtual dyno out now. |
04-21-2020, 11:34 AM | #18 |
Rep 354
6.4 was the 6th and final log taken. Also drove the car very spiritedly on the way to my logging location. Should be why IAT's are so high right?
On the drive home, with no change in driving style and while on 6.4, IATs stood between 79-82. IT was 54-56 outside. EDIT: After the 5th Log on 7.1 91 OCTANE. immediately flashed 6.4 and took the final log. |
04-21-2020, 12:35 PM | #19 |
Rep 7,633
You have a huge throttle closure in the 7.1 log. Just one this time (compared with multiple in the 93 one from before), but it is a big one. I think you would have felt that in the car. It's like due to the overboost. I think this is a common thing other people were reporting on 7.x versions, although i thought 7.1 fixed it for most people. Timing is not very clean on the 91 log either. Theres 3 degrees of difference between cylinders in several places, sometimes more. What plugs are you using and how many miles on them?
I would probably send both the 7.1 93 and the 91 logs to PTF and ask them if they look OK. I am still very surprised with your IATs. Not only the actual temp but how much it rises during a pull. I just looked back at some of my logs to confirm and my IATs are usually <10F higher than ambient temp, and over the course of a 4th gear pull, they increase by <5F. https://datazap.me/u/thejeremyman9/4...0&data=4-13-25 In your pulls, IATs rise by like 20F, and start significantly above ambient temp. Timing is all over the place in the 6.4 log as well, but you dont have a throttle closure. |
MAKH 588.50 |
04-21-2020, 12:50 PM | #20 | |
Rep 354
What causes throttle closure and where can i look for evidence of that in the log? Could it be anything I'm doing wrong during the pull? I cant say i felt anything abnormal during the pull. Also, what symptoms occur during a throttle closure that i would notice while driving? What intercooler do you have installed? Im starting to regret purchasing the one i got from turner motorsports. Going to send the logs to PTF lol. This is nuts. |
04-21-2020, 01:18 PM | #21 |
Rep 354
I distinctly remember letting off the pedal slightly in the 7.1 log somewhere around 4500-5000rpm and then kicked it back down (felt the pedal click) immediately to full throttle. Made sure to not do that while taking the 6.4 log. Could that cause throttle closure?
Im looking around on the forums for throttle closure causes and explanations. I feel lost at this point. Waiting on PTF to respond as well. |
04-21-2020, 01:43 PM | #22 | |
Rep 7,633
