How to free aluminum bolt stuck in aluminum block?
04-20-2020, 09:49 AM | #1 |
Rep 823
I removed my transmission this past weekend and found one of the aluminum bell housing bolts was already snapped. I snapped a second one during removal (and seriously jacked up my pinky when it gave out). With the transmission removed I have all the clearance I need to get at both of these studs. They're pretty big bolts. I guess I can't understand why they're stuck in the first place. We're talking about aluminum bolts in an aluminum block. Anyhow, I've tried channel locks, heat and beating on them while wrenching. I'd like to avoid drilling them out if I can. Does anybody have some amazing advice for me?
04-20-2020, 11:13 AM | #2 |
Rep 9,209
Drill a hole and hammer in Torx socket. Aluminum is soft and will take the shape of the Torx. Start small so you can go up in size if needed. I have broken one of these bolts, two from oil pan and one from oil pump working on various n54 engines and used above technic to extract them.
04-20-2020, 11:21 AM | #3 | |
Rep 823
04-20-2020, 11:41 AM | #4 | |
Rep 9,209
) are getting damaged under tension from the transmission hanging on them. |
04-20-2020, 12:10 PM | #5 |
Rep 823
I'm just a tad bit frustrated now. I can't see these bolts budging for anything. I pounded in a T40 and it immediately split the end of the stud in two when I wrenched on it. I can't believe they didn't use steel to begin with. I loathe aluminum bolts.
04-20-2020, 12:16 PM | #6 |
Rep 532
Drives: 2007 E70 4.8i, 2008 E90 335i
Use a left handed drill bit and if it doesn't come out while drilling then get an easy out in the hole that it made.
Often when you drill in enough with the left handed bit it will just come out due to the removed material and the fact that the left handed bit is constantly putting a "screw out" force on it. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
04-20-2020, 12:24 PM | #7 | |
Rep 3,926
But if the end of the stud is exposed sufficiently, you can use a stud extractor. |
feuer4277.00 |
04-20-2020, 01:06 PM | #8 |
Rep 823
I've been able to get a tremendous amount of force using locking pliers. A smaller Torx bit pounded into aluminum wouldn't do better. I also tried my bolt extractor and again was able to get some really good torque on it, but the stud eventually deteriorates and fails before breaking loose. I appreciate the suggestions!
04-20-2020, 07:24 PM | #12 |
Rep 256
04-20-2020, 09:27 PM | #13 |
Rep 823
I ended up getting 1 out of 2. I'm OK with that. The second stud ended up breaking off flush with the block and I'm not going to drill it out. It's the same one that was already broken before I removed the transmission, so I'm not too concerned. Anyhow, my jam nut method was working until it stripped the threads. I went back to the bolt extractor and it worked on one of them. I mean, it was working on both before it sheared off the second one. I really don't like aluminum bolts.
04-20-2020, 09:29 PM | #14 | |
Rep 823
04-20-2020, 09:31 PM | #15 | |
Rep 256
04-21-2020, 03:24 AM | #16 | |
Rep 3,926
stewbets448.50 |
04-21-2020, 09:30 AM | #17 | |
Rep 2,028
Just leave them imo. The bellhousing will be just fine without two bolts lol. |
feuer4277.00 |
04-21-2020, 10:54 AM | #18 |
Rep 823
