04-22-2020, 01:13 PM | #2 |
Rep 9
04-23-2020, 06:32 AM | #3 |
Rep 1,480
Drives: 2020 M340Xi (G20)
Hi,
Is this widget displaying tire pressure & temperature of all tires -- sorry, I can't read Cyrillic? Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
04-24-2020, 05:29 AM | #7 |
Rep 50
I checked his instagram and asked him if this could be coded on G20 330i and he said yes. But still dunno how to do that.
PunkSinatra78.00 |
05-04-2020, 03:33 PM | #9 | |
330i M
Rep 4
I can’t remember which parameter is in bimmercode but I will try to remember or search for it on weekend. VD |
05-04-2020, 10:29 PM | #10 |
Rep 50
That would be great. But how did you find how to code that then?
05-05-2020, 01:23 AM | #11 | |
330i M
Rep 4
If O find some time I will try to find out the other line and remember the one I modified. I will write it here. VD |
05-07-2020, 10:22 AM | #12 | ||
Rep 1,480
Using E-Sys, I just scoured DKOMBI4 CAFD (Instrument Panel) for anything with RDC, Reifen (tire) Druck, Safefy & RDC_Safety and unfortunately came up dry Do you recall what function you changed? Thanks
Al
05-07-2020, 05:37 PM | #13 | |
330i M
Rep 4
I will find it again for sure. I hope, because I need to remove 2 widgets that appeared after coding another to lines but don’t work properly. One is turbo pressure and water temp. The second widget I have to get rid of is M widget for steering, brakes and engine configuration. VD |
05-08-2020, 03:26 AM | #14 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
If you can, can you send me the ncd file of the dkomb so I can search for it to?
Haven’t had a G20 yet to code. So it will help allot to search actively to! |
05-08-2020, 06:05 AM | #15 | |
Rep 17
Thank you! |
05-08-2020, 07:02 AM | #16 | |
Rep 48
Do you also have any idea about how to enable the G- Meter widget on the live cockpit and the ID 7 ? Could you also take a look on that? My car did not come with this widget enabled from the factory |
05-09-2020, 01:53 PM | #17 |
Rep 1,480
Hi,
Went exploring through DKOMBI4 with Bimmercode in Expert mode and ran across CB_WIDGET_GWSZ_TWSZ, under Configuration function & it was not active Anyone have any idea what this is? Is this the tire pressure & temperature widget? Thanks
Al
05-09-2020, 09:30 PM | #18 |
Rep 325
I'll test later but that might be it, thanks for that, I will confirm if it works
05-10-2020, 02:27 AM | #19 |
Rep 20
Now checked it. Don't work(( I will continue finding solution
05-10-2020, 03:07 PM | #21 | |
Rep 1,480
Therefore, what I thought was a good lead is a not Sorry!
Al
05-12-2020, 05:00 AM | #22 | |
Rep 50
