N54 oil leak from pan?
04-22-2020, 08:58 PM | #1 |
Rep 41
So I was diagnosing an oil leak I've had for a while now so I degreased my engine and cleaned it all up from the bottom.
After cleaning I've found a few droplets of oil under my engine and I would assume it's from the pan but I see fresh oil droplets on the bolts above the pan, fresh oil droplets on the steering rack and the bolt above it(see photo), and fresh oil between where the engine and transmission meets. Here are some photos Any suggestions if it is the pan or anything else?? Looking to repair anything that's causing this leak. |
04-22-2020, 09:26 PM | #2 | |
Rep 41
04-23-2020, 02:52 PM | #3 |
Rep 466
looks like 100% for sure you will need to change he oilpan gasket. You may of other leaks but that is the main one for sure. Its a very heavy labor intensive job so god luck. Its a great time to do the job now since the stay at home orders because of the virus.
2007 e90 335i
pure stage 2 DD turbos, rb inlets |
