04-27-2020, 03:59 PM | #1 |
Rep 55
Should I be concerned about this?
I have not been able to drive my used 2016 435i x for 3-4 weeks due to the virus epidemic. As a result, when I started to drive it today, I noticed that there was something immediately wrong with the brakes being stiff and wonky.
But after driving the car for around an hour, the braking issue became less pronounced and improved somewhat. After driving the car, I took some pictures of the brakes / calipers. Should I be concerned about this? Should I bring it in the dealership to get this taken looked at? Also I just noticed after taking the pictures that the 2 front wheels have this metal cover that encases the calipers, but the two back wheels do not (as shown in the last picture, sorry I forgot to take pictures of the front two wheels' brakes / calipers. What do you think would be the best solution to remedy the situation? Thanks! photos are clickable links for larger images. K |
04-27-2020, 04:32 PM | #2 |
Rep 790
rust build up happens on the rotors but will go away after some driving, the build up on the caliper itself you are going to want to try and clean. next time you wash your car just spend a little more time there, maybe use a plastic bristled brush with a short handle that will give you some reach. not something to be too worried about or requires a dealer visit.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
04-27-2020, 05:49 PM | #3 | |
Rep 55
04-27-2020, 06:42 PM | #4 | ||
Rep 790
04-28-2020, 12:47 PM | #5 |
Modder of everything I own
147
Rep 491
What they said...rust.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
04-29-2020, 11:14 AM | #6 |
Rep 10,322
It could very well be rust combined with glazed rotors / pads + something else.
There isn't a need to take the car to the dealer. Reputable indy shop can inspect the brakes and give you an accurate assessment. Better be safe. |
