04-29-2020, 09:51 AM | #1 |
Rep 5
Grinding noise / soft vibration felt on slow accelerations
Over the past month I've been hearing a grinding sound coming from the front end of my 2015 335i. It sounds like metal scraping and the soft vibration is felt on the steering wheel. After a few minutes of driving it gets a bit harder to replicate but on some slow accelerations you can hear it. Sometimes louder then other times. Engine sounds fine and at higher speeds I don't hear or feel anything. It's just on slow accelerations. Not even when I'm breaking.
I attached a link to a reddit post with a video of the sound. Any help would be greatly appreciated. https://www.reddit.com/r/BMW/comment...tm_name=iossmf |
05-04-2020, 12:21 AM | #2 |
BMW CCA Member
493
Rep 808
How many miles on your car? Some ideas:
1. Worn brake pads - although you should see a sensor or dash light about this. (The OLD days, when the pads were worn, you can hear them scrape as the brake is applied). 2. You might have a rock/stone stuck in between the pad sections - crazy uncommon, but maybe. 3. The brake shield may gotten bent toward the disc rotor - hit anything lately? |
05-04-2020, 01:41 PM | #3 | |
Rep 1,597
05-05-2020, 07:56 AM | #4 | |
Rep 5
05-05-2020, 07:57 AM | #5 | ||
Rep 5
05-07-2020, 03:44 PM | #6 |
Rep 1,597
05-15-2020, 09:53 AM | #7 |
Rep 4
Searching through old posts to see if I can diagnose a similar problem and found your comment. I hear a rubbing sound when I turn to the right while going slow, but nothing when turning left or straight. My front rotors are definitely worn. Curious why you were asking this question the original poster? Do the pads contact the rotors more when turning and cause noise if rotors are worn? My noise sounds like it is from the left front when this happens but I'm not 100% sure. Thanks in advance!
05-17-2020, 09:59 PM | #8 | |
Rep 1,597
05-18-2020, 09:40 PM | #9 |
Rep 4
