04-30-2020, 05:22 AM | #1 |
Rep 4
Advice sought ...
Have recently picked up new M2 Comp in LBB as an upgrade from 2014 M235i.
Just had it lowered via KW Has V1 along with some graphic wrap detail to break up the blue. Considering a Stage 1 ECU tune when the 2000 kms ticks over - any thoughts and what should I look for or expect ? Feedback or advice welcomed ... |
05-08-2020, 04:25 AM | #3 |
Rep 98
I've read that on the BM3 FB page newer M2 comps require to be benched flashed to unlock the ecu and there's no eta of a fix. I ran BM3 for a while before going a custom ecutek tune, the BM3 OTS tunes definitely pulled damn hard and there was a lot of adjustability. You can play with like burbles, cold start, cooling modes etc. They're also adding switchable maps in future releases, but I don't think the integration is as good as ecuteks as you use the throttle to change maps whereas ecutek uses the cruise control toggle
05-09-2020, 12:34 AM | #4 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
Ya correct, if the m2 has had the latest DME update then flashing through OBD is not possible
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
