05-03-2020, 12:13 PM | #1 |
Rep 1,113
Sidemarker delete
I think i got side marker delete working.
I changed type from 5U93 to 5U91 in VO and coded both FLM2 modules. The amber headlight parking LED's are off now.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 05-03-2020 at 05:25 PM.. |
05-03-2020, 08:06 PM | #2 |
Rep 1,113
[IMG]undefined[/IMG]
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
05-03-2020, 08:19 PM | #3 |
Rep 751
Be careful, there are voltage changes to some of the bulbs (turn signal IIRC) and other owners (myself included) ended up getting errors due to this. You should compare the NCDs before and after coding, and revert all voltage or non sidemarker related changes
greekcs773.00 |
05-03-2020, 10:19 PM | #4 |
Rep 1,113
I'll compare the files tomorrow. no errors so far.
05-04-2020, 10:59 AM | #5 | |
PWRDBYM
36
Rep 76
05-04-2020, 11:23 AM | #6 |
Rep 1,113
I didn't FDL code the modules. I replaced the US body code (5U93) with that of a European version (5U91) in VO. I then activated FA and coded FLM2.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 05-04-2020 at 11:33 AM.. |
Poochie9106.00 |
06-06-2020, 07:16 PM | #11 |
Rep 751
Here are the differences I noticed when generating an ECE NCD for my car in regards to FLM.
LM03 is the sidemarker (notice all the [00] values for ECE to turn it off) LM01 is the turn signal (US is supposedly brighter) |
imported_nick82.00 |
02-12-2022, 04:05 AM | #12 |
Rep 1,124
Bringing up an old post...did VO coding the FLM module change your light distribution pattern to EURO. The Euro headlights have a distinct line of light vs the spread pattern in US. Did it also activate your High Beam assist?
02-12-2022, 05:31 AM | #13 |
Rep 464
No, not in my case. FYI, BDC controls VLD and Anti-dazzle/NGHB in my M340iX.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
06-05-2022, 05:23 AM | #15 |
Rep 9
Turn off the amber light
Hello, Is it possible to turn this side light (yellow) turn off? This light turns on during night time.
https://ibb.co/tZqrYnd If someone can help, would appreciate. Thanks |
razzle4544.50 |
01-24-2024, 04:13 AM | #16 |
Rep 2
I have the laser lights and I ended up VO coding in 5U91 on my FLM modules and the side marker is indeed off when the headlights are on. Is it just me or do you guys notice a noise when the lights do their start up "look around" specifically when the lights look down?
I have anti dazzle coded in as well if that makes a difference |
02-07-2024, 03:22 PM | #17 | |
Rep 106
Drives: 2023 BMW 330e LCI M - Sport
02-13-2024, 11:01 AM | #18 |
Rep 160
Hi all,
I recently did this. These are the only changes you need to turn off the sidemarker in the headlamp without any error codes: Code this in both FLM modules.... Now I'm still trying to figure out how to make the mirror sidemarkers stay constantly ON when not indicating; anyone know how on G20? It's easy on G30 and other chassis, but seems G20 is different. |
pdxtiger28.50 |
02-15-2024, 09:04 PM | #19 | |
Rep 106
02-21-2024, 02:04 AM | #20 | |
Rep 872
Drives: OG M2
OG M2 with the OEM M mirror retrofit
02-21-2024, 12:28 PM | #21 |
Rep 106
I can’t get them off on my 2023 G20 LCI for the life of me!! Would pay to get these things off!!
02-22-2024, 09:24 PM | #22 | |
Rep 12
s correct. Instead of coding LM03, I coded LM11, and only this set: LM11_DUTY_CYCLE_BINNING_CLASS 0-4 to Wert_2 (00). Seems like LM03 equals LM11in the LCI cars. Attached a photo showing what it looks like. View post on imgur.com |
Calvindubois42.00 imported_nick82.00 |
