Idle 1200 rpm
05-04-2020, 09:48 PM | #1 |
Rep 107
Idle 1200 rpm
I just turn mhd and notice the setting idle for 1200 i'm not sure if i accidentally did that or that was default ... but Is 1200 rpm idling bad or good or don't matter??
05-04-2020, 10:39 PM | #3 |
Rep 107
Yea that's how it was before i tunes it and played with the setting on MHD so you believe i should just bring it back down to stock rpm
05-04-2020, 11:57 PM | #4 |
Rep 940
is it just me or are these fourms getting flooded lately with braindead questions ?
2007 E92 335i / FBO + Inlets / E85 Custom Tune by WedgePerformance / 9.68 @ 140 / TPC Stage 2 19T / 2.1s 0-60 mph / 2010 535Xi 6MT - 437M - MHD / Instagram @Silent9n54
05-05-2020, 06:12 AM | #7 |
Rep 107
hahaha i gotchu lnao appreciate it though
05-05-2020, 07:41 AM | #8 |
Rep 564
I probably wouldn't go up to 1200 rpm, but mine is set to 900 rpm because of my SMFW and it drastically reduces the chatter at idle. I'm sure many others have done the same but 1200 is a bit high. There may be a use case for it but I'm not sure what it is.
dyllan1213.00 |
05-05-2020, 08:08 AM | #9 |
Rep 107
understandable, thank y'all again
05-05-2020, 09:58 AM | #10 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
1200 is not going to hurt. Just likely uneeded. I run at 900rpm all day every day and have for years. No issues. Still very low in the rev range and zero load.
05-05-2020, 10:08 AM | #11 |
Rep 3,732
I guess I don't really understand what the issue is here. You installed MHD.....and you accidentally set the idle to 1,200rpm somehow...........so why don't you take 45seconds, put the idle back to the stock setting with MHD, and reflash the car? Why leave it?
Torgus3781.50 |
05-06-2020, 02:38 PM | #12 | |
Rep 230
05-06-2020, 02:41 PM | #13 | ||
Rep 107
05-06-2020, 03:10 PM | #14 |
Rep 203
Mine was had an idle at around 1100-1200 even after warming up a bit, I reset adaption for the car and it was fixed immediately
I would also consider looking in to plugs and coils if you haven't done that yet and a walnut blast wouldn't hurt, could be mhd trying to compensate for one of those two things Try clearing adaptions first and go from there
Crimson LCI E90 N54 auto - sold
Lemans LCI E92 N55 manual - current |
05-06-2020, 03:12 PM | #15 | |
Rep 203
05-10-2020, 10:02 PM | #16 | |
Rep 3,219
No idea what made you think bumping the idle speed to 1200rpm was a good idea, just bring it down to about 700rpm. 1200rpm is the approximate idle speed when the engine cold starts, obviously not normal to idle at that speed. |
