05-07-2020, 07:37 PM | #1 |
Rep 81
TTFS XDI-35 Chirping!
First of all i would like to apologize because i made the original post in the wrong location. However, I have a 2015 335i x drive on a stage 2 custom tune and have been getting this rattle ever since I installed the XDI-35.
here is another video but this is unrelated to the HPFP just stupid loud If anyone has got any clues let me know! i have searched a lot on these forums and haven't found noises similar too these |
05-07-2020, 08:11 PM | #2 |
Rep 7,632
First video - did you actually listen underhood and confirm its from the pump, or it just happened at the same time as the pump install? If you had a shop install, i would have taken it back immediately...
Second video - see my thread here. Sounds similar, but mine was under accel not decel. Could be the same issue though; easy to check. https://f30.bimmerpost.com/forums/sh....php?t=1708574 |
F22ryan8.00 |
05-07-2020, 08:26 PM | #3 | |
Rep 81
And thanks for the video! That definitely gives me some sort of idea of a location it could be these noises are insanely difficult to locate |
05-07-2020, 08:51 PM | #4 |
Father of Frankenfold
300
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
They chirp. Mine has chirped since day one.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
05-07-2020, 09:10 PM | #5 |
Rep 7,632
05-07-2020, 09:59 PM | #6 |
Rep 1,105
So this happens on my ots PS2 map but once I went custom tune through Pureboost, it just went away.
Recently reflashed the ots map because I didn't have time to go mix my E30 blend for my custom tune. Noticed the chirp sound came back on ots map but not on my custom tune. Very odd. |
05-07-2020, 10:02 PM | #7 | |
Rep 81
05-07-2020, 10:13 PM | #8 |
Rep 1,105
05-08-2020, 07:12 AM | #9 |
Rep 81
Just 91 octane and Paul Johnson tunes
05-08-2020, 09:35 PM | #10 |
300
Rep 531
I run E30, sometimes E40. Rarely 91 octane only. It chirps with any fuel and any tune, OTS or custom, from what I recall.
05-08-2020, 09:49 PM | #11 |
Rep 1,105
05-10-2020, 11:37 AM | #12 |
Rep 354
Once you get a custom tune it will disappear. Its the rail pressure from what I understand. My tuner got rid of it first revision. I'd just ask your tuner to get rid of the HPFP chirp. They should be familiar.
05-10-2020, 11:39 AM | #13 |
Rep 354
Its not even that annoying. Not enough to pass up on its benefits at least... For me.
05-10-2020, 11:44 AM | #14 | |
Rep 354
Ended up zip tying mine until the zip tie broke. Bmw ended up fixing it under warranty as well. 😅 |
05-12-2020, 08:54 PM | #15 |
Rep 81
Update!
I have spent 4 hours looking forward into all the issues suggested so I ended up bringing it in and now has been there for 3 days... so far the harmonic balancer has a wobble could be the issue and they said after it was replaced there is still a wobble. I cannot remember exactly what they said but apparently the crankshaft is slightly moved out about a .10th of a millimeter and now I am scared shitless
05-14-2020, 09:52 AM | #16 |
Rep 3,052
Drives: 2019 M2 Competition
My pump would chirp initially with my OTS tune right after I isntalled. It was resolved in the BM3 OTS tunes later, and also immediately addressed when I changed to a custom tune from Cary Jordan.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
