BIMMERPOST Universal Forums Off-Topic Discussions Board Water softener valve
      05-08-2020, 01:50 PM   #1
LOW4LYF
LOW4LYF's Avatar
2231
Drives: E92 M3 & F85 X5M
Question Water softener valve
Just found out my house has a water softener which I never uesed before...lol
Well the issue is I don't know what position the valve is and I can't turn it at all.
Just wanted to make sure I don't break anything.
How do I know what state the system is?
How do I turn this damn valve handle?
Thanks!
https://ibb.co/sw8tB9n
https://ibb.co/n3SZpZT
      05-08-2020, 02:22 PM   #2
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
Left loosy righty tighty...that's all i got.
kscarrol9999.00
E93Beast632.50
wrickem2258.00
      05-08-2020, 02:26 PM   #3
2000cs
Drives: Potato
From the Kinetico.com website:
We're happy to help you in any way we can. If you have questions, comments, praises or concerns, we'd like to hear from you. Here's how to get in touch:
24-Hour Support 1-800-944-9283 or Email Customer Service
      05-08-2020, 05:38 PM   #4
LOW4LYF
LOW4LYF's Avatar
2231
Cool...gues gonna email them!
Thanks
      05-08-2020, 05:42 PM   #5
RickFLM4
RickFLM4's Avatar
Drives: M4
You will need to get it serviced. Filters need to be re-bed every 2 years and softeners every 5-7 years. I’d get it serviced before flowing water through it into your house and hot water heater.
I assume there is a tank / canister nearby to fill with salt?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
Violator4596.50
Rmtt8201.00
      05-08-2020, 07:50 PM   #6
LOW4LYF
LOW4LYF's Avatar
2231
The house is pretty "new" and it wasn't running maybe for 6 months.
I have the salt filled and was able to run the system but still can't figure out how to turn the valve...lol
Not so important at the moment but still bugs me.
      05-08-2020, 08:35 PM   #7
Mine is vertical when in use and shows green under the notch in the valve handle.
      05-08-2020, 08:39 PM   #8
LOW4LYF
LOW4LYF's Avatar
2231
Which would make sense for me. I watched couple videos on YouTube but no one was the same system as in my house. I don't have any colors showed at all.
      05-09-2020, 12:26 PM   #9
jwzimm
jwzimm's Avatar
Drives: '16 M3
I would expect that you should see a symbol where that arrow is pointing that corresponds to the three states listed on the valve body. Yours appears to be in an indeterminate state either past the allowed rotation or in between settings. If it is jammed I would leave it alone and contact a plumber who knows about those valves. Best not to mess with it and result in disabling the water supply to your house which would result in an emergency call to a pulmber.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      09-03-2020, 12:18 PM   #10
AsiaHorner
Guest
n/a
Drives:
Dude, I recommend you don't try to fix it by yourself. You can add more troubles. It will be well, if you call the plumber from a reliable service and he will do diagnostic. After I had read a lot of stories about these filters and how do they are difficult collected, if I have any questions I always write in support of water softeners San Diego. Well that it works anytime and they provided me very long guarantee on my filter. I think that it is easier than to look for breakages by yourself. Hope that you have sorted out
