BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Cracked Ceramic Break Rotor **HELP NEEDED**
      05-17-2020, 01:47 AM   #1
KBM5
Drives: 2018 F90 M5
Hello Guys,
So today I was about to go on a drive with my 2018 F90 M5 and a noticed something unusual on my driver side Ceramic Break Rotor. I had a closer look and it looked like a piece of my rotor just fell off and left a hole (look at the pictures attached).
My car has 23,000 Kms on it, I maintain extremely well, I'm extremely cautious with it. The car has been tracked once in its life about a year and a half ago, I also often go for spirited drives, and the car is winter driven as well in Montreal QC, where it gets VERY cold. When I do use my breaks hard, I do give them a cool off period of at least 3-5 minutes of slow driving to air off the heat from the disks before completely stopping, and make sure I do not over heat my rotors. I use the car how it is meant to be used, mostly on highways for speed runs and or twisty roads a times, but again never abusing my breaks. Again I'm very cautious.
Therefore I have the following questions:
I was wondering what could've caused such an issue?
Is this something that can be covered under the warranty?
Can I still drive the car in the mean time? How safe is it?
Thank you guys for any help or insight you have on this issue!
      05-18-2020, 12:00 PM   #2
marcvtec
Drives: M5
Send the pics to your service - I would not drive it, only looks like it would get worse, and yes I would want this to be a warranty item.
      06-02-2020, 08:01 PM   #3
Demon Barber
Drives: 2018 M5, 2022 911 Turbo S
Where did the rest of this entire thread go?
      06-03-2020, 01:59 PM   #4
kdeleon
Drives: M5
It’s still in the general thread. There were multiple posts put in separate areas.
https://f90.bimmerpost.com/forums/sh....php?t=1721364
      06-03-2020, 03:43 PM   #5
Demon Barber
Good call, thanks. I was worried it got deleted somehow.
      06-25-2020, 09:07 AM   #6
8th_Sin
Drives: 18 R8 V10+, '18 Raptor, 911 TS
I had CCBs on my 911 Turbo S and occasionally a rock hit justttt right and can damage them, even if being very cautious.
Hope things worked out for you!
m5post
