05-20-2020, 03:38 PM | #1 |
Rep 28
Drives: 2020 230i
Crummy AppleCarplay Sound?
Apologies if this has been covered in the past.
Firstly, I made sure to get the HK stereo upgrade for the 2020 230i. The folks at the dealership walked me through the carplay setup. Over time, I started to realize that something wasn't quite right...the quality wasn't up to snuff. I messed around with the tone settings....a little better but not that good. AM radio sounded better. I did a little research regarding this issue and it seems to be rather common. The EQ settings on the phone itself seemed to be a point of contention? Anyway, so I deleted the phone from the car and the car off of my phone's Bluetooth profiles. Also, I disabled my phone's EQ settings. Solution: This time, I didn't enable Carplay right away. I simply added the device via bluetooth first, then it asked me to initialize Carplay...so I did that. Music quality is much much much better. Now the soundstage is happening. Hope this helps. |
05-21-2020, 05:25 PM | #2 |
Rep 776
Have you tried connecting it via AUX to see if you can duplicate the Bluetooth issues?
I just got my M240i with HK about a week about and I plan to try your fix if AUX sounds better than Bluetooth because damn, this base 230i loaner has a better sound system than my HK M240i! Something isn't right.
M240i | Mineral White | Coral Red
05-22-2020, 07:32 AM | #3 | |
Rep 28
Drives: 2020 230i
I have not tried the Aux channel. However, I will say that the method I tried is night and day better then before (bluetooth first then followed by Apple Carplay). IMO this seems more like a sequence issue with iDrive's Apple Carplay implementation.
Nonetheless, I'll try the Aux channel (provided I can locate the port if it even exists) if not I'll test via USB. Quote:
05-22-2020, 09:26 AM | #4 |
Rep 422
