Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Different coding
      05-23-2020, 03:08 PM   #1
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
Different coding
So I have been playing around with BimmerCode TestFlight and wanted to code lane change, but BimmerCode don’t have the SAS2 module so I had to use Esys. But inside BimmerCode I found some possibilities to code traffic light and stoplight so I played around with. I will let u guys know how the process is.
      05-23-2020, 06:14 PM   #2
mlavio829
Drives: 2020 BMW 330i X Drive
That’s neat. What would that allow you to do exactly?
      05-24-2020, 12:42 AM   #3
Basti@G20 320D
Sweden
25
I am hoping that the car can see the stoplight and automatickly stop
      05-24-2020, 07:25 AM   #4
mlavio829
That would be amazing!
Any luck?
      05-26-2020, 01:43 AM   #5
Basti@G20 320D
Sweden
25
I ises this weekend to try to see what I could find out and I get the check box in settings, but it doesn’t seam to do anything, but my problem is also that autonomous driving is very different in each country. Meaning what the car can do in Sweden, it might not be able to do in Germany.
      05-26-2020, 01:59 AM   #6
Watzek
Watzek's Avatar
9
Drives: BMW G20
I have tried to code the traffic light assist in e-sys by activating yellow marked values. Unfortunately no change. The car drives full speed over the traffic lights (it tries )
If someone has an idea please share it. I assume that further unites has to be coded (e.g. MGU)
      05-26-2020, 04:49 AM   #7
mrgicm
mrgicm's Avatar
446
Drives: BMW M
Yield Waring in US or Give way waring assist how its called in Europe requires many modifications to county and land masks in SAS,KAFAS,BDC,DSC and MGU unit.
      05-26-2020, 06:22 AM   #8
Watzek
Watzek's Avatar
9
Drives: BMW G20
I can already see the red traffic light and stop warnings in the digital cluster. I assume that I have to activate a dedicated menu in MGU as I have it done with lane change assist.
It would be great if someone could activate that feature. That's one of the few things which stops me to use ACC permanently
      05-26-2020, 11:37 AM   #9
sd_dracula
Drives: 2020 G20 330e
Was this achieved by enabling the above or you had the traffic light already showing in your dash before?
The stop sign/yield signs do pop up automatically so that is already enabled.
      05-26-2020, 03:23 PM   #10
Watzek
Watzek's Avatar
9
Drives: BMW G20
Traffic lights indication is a standard OEM feature right from the beginning (Nov '19)
      05-26-2020, 05:33 PM   #11
mrgicm
mrgicm's Avatar
446
Drives: BMW M
Yes but it is country locked, if you go across the border to Austria it still works but as soon as you enter Slovenia it stops working,and you get a note function not available in this country.
      05-27-2020, 01:15 AM   #12
Watzek
Watzek's Avatar
9
Drives: BMW G20
I have read that BMW works on that feature with their test vehicles and shortly before general release. If someone has a country specific coding I can check that for Germany.
      05-27-2020, 01:58 AM   #13
Basti@G20 320D
Sweden
25
When i went in the settings i saw there were many options where you could chose witch generation u wanted gen 1 gen 2 gen 3, but if someone could find all the diff modules to code, cos there are many, and how to code that the car thinks its in china, where automonomus driving is legal, that would be great
      05-27-2020, 02:56 AM   #14
sd_dracula
Got my car in Sept 19 so it either has it disabled due to country (like the lane change assistant that I enabled myself) or it needs newer software.
Would be nice to know which settings are for the traffic lights display to try and toggle them on
      05-27-2020, 07:13 PM   #15
mrgicm
mrgicm's Avatar
446
Drives: BMW M
No need to code china, you can just code of country and land values off. Even still it will not work in some countries.
      05-29-2020, 09:29 AM   #16
mlavio829
This would be amazing if we could enable this.
We don't have the traffic light info in Canada.
      05-29-2020, 11:02 AM   #17
sd_dracula
Also very interested in the traffic light bit.
Even if it doesn't stop for them
      06-01-2020, 03:20 AM   #18
Watzek
Watzek's Avatar
9
Drives: BMW G20
The icon doesn't appear for every single traffic light, only if you approach it to fast
      06-01-2020, 03:30 AM   #19
sd_dracula
Ah ok similar to the yield/stop sign it seems as that also doesn't pop up every time.
      06-02-2020, 04:56 AM   #20
Basti@G20 320D
Sweden
25
I messed around with it in the weekend and it seams its country specifik.
Watzek8.50
      06-02-2020, 12:26 PM   #21
sd_dracula
What did you enable for the traffic light options? Or you had them available already before any coding?
      06-02-2020, 02:33 PM   #22
sd_dracula
@joewaschl/@basti - so I went and coded the same 4 values from above but no luck, the menu isn't even showing for me.
Either it is due to country or you guys have newer software than me.
What version do you have? Mine is 07/2019.38 - as it came from the factory
g20
