06-02-2020, 11:55 AM | #1 |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Thinking about coding with Bimmercode app
Looking at getting into coding for my G20. I think I will go the Bimmercode route but would like some advice on OBD adapters.
Looks like the cheapest option would be an ENET cable and Ethernet adapter. The ethernet adapter would need to connect to my iPad/iPhone. Would I have the same functionality in Bimmercode App. Compared to using something like OBDLink MX+ Bluetooth. Any help/views appreciated.
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R Last edited by Tam the Bam; 06-02-2020 at 12:23 PM.. |
06-02-2020, 02:22 PM | #2 | |
Rep 59
Hello OP, I just ordered this Bluetooth OBD from Amazon that a lot of folks with the F30 use. You can use coupon code YTBDST15 for 15% at checkout. https://www.amazon.com/dp/B073XKQQQW..._wAQ1EbZB7GBVK Looks like it arrives on Thursday and I will begin to play around with it on Friday when I get my car back after it is finished with the PPF install. I'll post back with what I find out and code. |
uncoturner5.00 |
06-02-2020, 04:55 PM | #3 | |
Grumpy Old Git
443
Rep 923
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
06-02-2020, 05:17 PM | #4 |
Rep 1,480
Drives: 2020 M340Xi (G20)
@Tam the Bam,
Though I have used E-SYS & ProLauncher to code for some time, I also have recently gone to Bimmercode with OBD MX+ link and have found it quite useful! I would recommend that you turn off car's Bluetooth & if you wear a Bluetooth watch (like a Fitbit) off when coding-- minimizes any chance of interference problems Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
Tam the Bam442.50 |
06-02-2020, 07:54 PM | #5 | |
Rep 30
Tam the Bam442.50 |
06-04-2020, 05:34 AM | #6 | |
BMW4LIFE
30
Rep 35
Tam the Bam442.50 Swagasaurus-R3X44.50 |
06-05-2020, 04:10 PM | #7 | |
Rep 59
I was able to program the head unit and display unit start up animations and it worked great. Also coded the video in motion even though I am not planning on using it. I'll check back in once I recieve the OBDLink MX+ in the mail. |
06-05-2020, 04:23 PM | #8 |
Rep 156
I'd go with Ethernet option. It's quicker, you can access all the menus, and also gives u the potential to code with esys later on if you choose.
06-05-2020, 08:58 PM | #9 |
Rep 157
I agree and that’s what I did after buying a VeePeak that was at one time recommended by Bimmercode but then not. Instead of being subject to which BT OBDII dongle works at any given time, the ENT cable will always work, is faster, and more stable. Cost is about the same once you factor in the adapter for Ethernet to Lightening or whatever.
06-07-2020, 01:24 PM | #10 |
Rep 59
Update: I went with the Ethernet option. Bought it on Amazon and it arrived in 1 day. Started coding some basics like the head unit and flashing break lights.
Currently need the beta BimmerCode app in order to access the Headunit expert mode. |
06-07-2020, 01:26 PM | #11 |
Rep 156
Do the flashing brake lights work for you? I tried testing and couldn't get them to flash.
06-07-2020, 03:00 PM | #12 | |
Rep 59
Let me know if you find a solution. |
07-05-2020, 10:05 AM | #13 |
Rep 46
I was going to start doing some coding soon and it looks like most prefer the esys ethernet cable.
Is there special software needed ? If I use my android phone to use the bimmercode app what other adapter is required to connect to the phone? I'm use to OBDeleven on VAG products. its an all inclusive dongle. |
07-05-2020, 10:16 AM | #14 | |
Grumpy Old Git
443
Rep 923
Retired:
07-05-2020, 01:08 PM | #15 | |
Petrolhead
1949
Rep 3,521
I use obdlink lx. I’m not a fan of it because it’s slow. But I can access all modules with it. I had a wifi vgate before that and that was much faster but it couldn’t access all modules.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
07-06-2020, 07:00 PM | #16 |
Rep 2,964
Had been using my vgate icar pro bluetooth (the same one I used on my F30 with Bimmercode - but as others have mentioned using this combination would not give me access to all the modules.
Just today received in the mail (thank you Amazon) an iphone to ethernet cable that I plug my OBD to ethernet cable into. Now I have access to all the modules and coding process is so so much faster. Thanks all for the suggestions - worked like a champ!! |
07-10-2020, 12:12 PM | #18 |
Petrolhead
1949
Rep 3,521
The OBD port is usually located at the same location for most cars. Check under the dashboard of the driver's side, close to the outer footwell wall. It should be open but in rare cases, some cars have a flap covering it.
Current:
07-11-2020, 08:43 PM | #19 |
Rep 31
So on Bimmercode when I enter my car type G20 these are the 3 adapters that come up that supposedly work with Android phones
MHD ENET Wi-Fi BMDiag ENET Wi-Fi modBMW ENET Wi-Fi Can anyone confirm this will work with a 2020 330i? Also seems like the ENET Wi-Fi is wireless - not a choice of either cabled or Wi-Fi. Wondering if anyone has experience with pros/cons of this. Thanks. |
07-11-2020, 10:01 PM | #20 | |
Rep 259
RJCmmr3.00 |
07-11-2020, 10:42 PM | #21 | |
Petrolhead
1949
Rep 3,521
Current:
RJCmmr3.00 |
07-11-2020, 11:35 PM | #22 | |
Rep 31
This will be my first coding too so it helps knowing you found it so easy. I'm in the US - what store did you order from - the ones listed through Bimmercode seem to all be in the UK |
