06-02-2020, 07:09 PM | #1 |
Rep 3,300
Anyone DIY spark plugs yet????
I can't find any videos on this for the F90. There are some for the prior model. Does not look that bad, but have to move a ton of stuff out of the way. Trying to decide to DIY or have dealer do it. 25k service.
Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
06-02-2020, 07:54 PM | #3 |
Rep 3,300
I figured by now someone would have posted some images....I guess it will be me...
Took down my RS6 myself to do the plugs and coils.....timing belt is a PITA. LOL. Mike
06-02-2020, 08:04 PM | #4 | |
Rep 4,088
I haven't seen anything but, aren't the spark plugs including during the first 3yrs 36k for original owner? Not sure what the service manual states. Same motor minus a few revisions as F10. How much is your time worth and what does the dealership charge lol? Certified independent shop maybe. |
06-02-2020, 09:22 PM | #5 | |
Rep 605
06-03-2020, 06:13 AM | #6 | |
Rep 4,088
If memory services me correct normally at Inspections I & II or every third oil change for M cars they recommend plugs ( 3yrs or 30,000 miles whichever comes first). I'm going to ask tomorrow as I'm going in for the 1st year (or 8K) oil change. |
06-03-2020, 10:48 AM | #8 |
Rep 3,300
FOUND IT! LOL
https://www.newtis.info/tisv2/a/en/f...ugs/1VncPuvtU2 Now I know what needs to be moved, removed, etc. Mike
06-03-2020, 02:08 PM | #9 | |
Rep 605
06-03-2020, 02:23 PM | #10 | |
Rep 3,300
I was looking at another breakdown sheet, on a different page of the same website, and they showed how to remove the coolant tank on the passenger side also. This breakdown does not mention it? I think it may be in error? I'll poke around this weekend, I took a quick look a few times, but as usual something else called me attention. At this point I am toying with keeping this car for 10 years and want to know if I can DIY for the routine stuff. Next thing to consider is the timing belt service. Those routine must be done things are different than the fix a broken part deals which would be covered by an extended warrantee. Mike
06-03-2020, 02:27 PM | #11 |
Rep 3,300
This "special tool" is simply priceless. Look at the name of it.
"Original Rubber Hose." This is the Original Rubber hose that was used to beat people back in Germany.
06-03-2020, 03:41 PM | #12 |
Rep 605
Haha, the "original" rubber hose. I totally agree that for those of us planning on keeping this car long term, we will need to know how to do stuff like this. I'd like to eventually have enough info and tools for transmission, transfer case, diff fluid changes, etc. I'd also like to install an oil catch can, but extra space is basically non-existent under the hood.
06-04-2020, 04:20 PM | #14 |
Rep 4,088
02-08-2021, 04:27 PM | #16 |
Rep 3,300
Dam, I should have copied all those pages. Sorry.
Here's what I recall. The two engine ECU's (one on each side) have coolant lines going to them, and they are apparently not flexible. So you need to move these out of the way. On the passenger side the Reservoir for the coolant has to be moved out of the way, the manual I believe recommended removing it, but my tech was able to move it without removing it completely. Those are the two items that are a bit of a pain. For the plugs, BMW strongly recommends vacuuming out the tunnel of each plug before removing a plug. Carbon deposits can end up in the engine otherwise. I did my Q7 a few weeks ago and did this, I didn't see much debris in there, but I could imagine this being a problem. The coolant line thing is what threw me off and said this time it's on BMW. I will eventually be DIY this for next swap but hopefully someone will have a good video on it. Or I'll make a shitty video on it. Mike
03-09-2021, 01:07 PM | #18 |
Rep 1,800
03-09-2021, 05:45 PM | #19 |
Rep 3,300
yes, I want a copy for 15 bucks. LOL. I paid 100 for my 2015 Q7 manual.
Mike
04-19-2021, 03:21 PM | #20 |
Rep 1,800
04-19-2021, 04:22 PM | #21 | |
Rep 3,300
Mike
