06-05-2020, 11:46 PM | #1 |
Rep 206
I bought the combo Active Auto deal at Extreme Powerhouse https://x-ph.com/active-autowerke-f-...pe-combo-deal/
...for my f32 and compared to how it felt before im happy. However, as I continue to get more obsessed with building my car im seeing more about other in and out pipes. Now im confused...is this the same pipe as a cold side pipe? Id really like to complete everything, just dont wanna buy the same thing i already have. There is a lag between gears which i hateeeeee. What cleans that up? Thanks yall! Thumbs up for the advice and recommendations
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
06-06-2020, 10:27 AM | #2 |
Rep 462
Charge pipe is what you got in the combination deal. Its the cold side pipe that runs from your upgraded intercooler to your throttle body.
You need a trans flash like XHP if you want faster shifts. Now that you have the intercooler and charge pipe, you should get a tune to take advantage of them. |
06-06-2020, 10:30 AM | #3 | |
Rep 206
06-06-2020, 11:20 AM | #4 |
Rep 462
Cold side pipe and charge pipe(CP) are two ways of identifying the same part. Which you have.
There is a pipe that runs from the turbo to the intercooler. It can be called a turbo to intercooler pipe(TIC) or hot side pipe. I have not heard of there being the reliability issues with the TIC as there are with the CP. So I dont know if there is a good reason to upgrade it unless maybe you are getting a stage 2 turbo. JB4 adds power via manipulation of the boost, fuel, and air signals going to the cars computer(DME). If you have a JB4 I highly recommend you get the MHD flasher and load a backend flash. That way the DME has more control and the JB4 just acts as a boost controller. With the DME doing most of the work, you will make a bit more power safer and smoother than the JB4 alone. JB4 does not do anything to the transmission except that it reports higher levels of torque to the DME so there is increased line pressure to prevent slippage with the added power you are making. It does nothing in regards to shifting. |
06-06-2020, 11:43 AM | #5 | |
Rep 7,633
With regards to the transmission tune, XHP is definitely the way to go, just take a look at the recent thread or the older one with 100s of posts in it. It will work fine with JB4, but if you want the best combination of driveability, power delivery, and overall power, you should go with a flash tune like MHD/BM3/AA/etc and XHP for the transmission. Just depends on what you goals are with the car. As mentioned above you already have the charge pipe (CP) and intercooler (IC). You would just need a downpipe (DP) if you wanted to run a stage 2/2+ tune. You would also benenfit from a DP with JB4. The TIC does not need to be replaced for reliabiltiy issues. Some do it along with IC+CP, others dont unless they are going turbo upgrade. |
06-06-2020, 12:09 PM | #6 | |
Rep 462
Thanks for the torque catch. You had me questioning myself. I went back and reviewed. The JB4 alone does not alter the torque signal. You have to have the BEF loaded for this feature. |
06-06-2020, 12:40 PM | #7 | |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
I'd suggest that you discuss your gear hesitation issue with Mike at x-ph. He's going to have a better idea of your options with your current configuration. I had a similar discussion with him and he helped me to not waste money by avoiding expensive suggestions that were being thrown my way. Mike impressed me when I've called him thinking I had to buy an expensive product from him and he actually talked me out of it. Turned out that there was a less expensive solution that better met my needs. Mike is a great resource. |
06-06-2020, 01:06 PM | #8 | ||
Rep 206
johnung4552.50 |
06-08-2020, 11:30 AM | #9 | |
BimmerPost Supporting Vendor
24492
Rep 191,493
06-08-2020, 09:26 PM | #11 | |
Rep 7,633
As i posted in the other thread, i would also recommend against BM3 for someone who does not know how to do logging or basic DIY like installing or removing a JB4. |
