06-08-2020, 09:01 AM | #1 |
Rep 41
Exhaust Design & Size (for maximum performance, NOT SOUND)
Hi...
I've looked into some of the threads and not sure if everyone have discussed this in much depth regarding the exhaust design and diameter size of the pipes for maximum performance. I've read threads on which sounds best but not enough discussion on performance... My 335i is on PS2 + HPFP RWD, ER downpipe with custom exhaust all the way back... Here's the design of my current exhaust (3" pipe all the way back), i was too reliant on my exhaust tuner and he made it JDM style like this...it looks really cool tho...but, I do feel there is a bit too many bends that would create backpressure which is not too good for turbocharged cars... My car makes 400whp+ and Ive been receiving advice that my exhaust should be 3.5" or 4" to ensure maximum velocity of the exhaust gas... Any take on this?
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
06-08-2020, 09:14 AM | #3 |
Rep 41
06-08-2020, 09:17 AM | #4 |
Rep 41
Akrapovic came with an interesting idea of splitting the mid pipe into a 2 x 2" pipe - which is interesting to me and it is a race-tested brand...
My exhaust tuner says he can make it like this, so I'm really intrigued but too afraid if the end result (after spending $$$) would not have any effect or even reduce the dyno numbers...
06-08-2020, 10:41 AM | #5 | |
Rep 7,629
If you REALLY want to know how much restriction your exhaust is causing, get a dyno session, do 3 pulls with the exhaust on, pull off the axle back, or if your exhaust is one piece, pull off the entire exhaust and run open DP, and do another 3 pulls and see what the difference is. I have seen this test done on other platforms with stock exhausts and the difference is usually only 2-3%. A well designed 3'' exhaust is plenty up to 500hp and likely beyond. But again, i wouldn't lose sleep over it. Also, whoever said you want to increase diameter of the exhaust to gain velocity has it backwards - increasing the diameter might allow more flow if backpressure is truly an issue, but its going to reduce velocity - a smaller pipe has more air velocity at a given flow than a larger one. |
alohasurftoad3130.50 |
06-08-2020, 11:26 AM | #6 |
BimmerPost Supporting Vendor
24477
Rep 191,448
All the dynos i have see show 5-8 HP more with high flow exhaust.
Does this setup offer more power?
06-08-2020, 03:30 PM | #7 | |
@_sunbish
294
Rep 612
06-08-2020, 04:05 PM | #8 | |
Rep 7,629
CG precision sells a DP with a 3.5'' exit and a 3.5'' exhaust to pair it with, IIRC. However like i said this is probably not going to net you gobs of HP, your talking maybe 10, not something like 50. |
06-09-2020, 08:57 PM | #9 | |
Rep 41
yeah, it is a big investment to bet on...
DreamerJoe253.00 |
06-09-2020, 09:15 PM | #10 | |
Rep 41
Also I found this on youtube, again this may not be the right comparison to BMW engines...(youtube link: )
06-09-2020, 10:47 PM | #11 | |
Rep 7,629
In response to the videos, i have seen engine masters (probably all episodes), but you can't extrapolate a engine like that to ours for numerous reasons... its not even forced induction, its not running a load or boost based tune, etc etc. While of course you want to minimize back pressure on any forced induction engine, what we are saying and what testing has shown is that that even the stock exhaust is not a major constraint at and above your power level. Also as mentioned above, the "choke point" is going to determine where the power loss occurs, which might not even be the stock exhaust. Bottom line, if you want to try it go for it, but i think you will be disappointed in the result. |
06-20-2020, 07:21 PM | #12 |
Rep 4,210
I did a LOT of research on exhaust gas theory for my last car (N/A) and back pressure is never good for any car. The stock exhaust may be more restrictive as power levels rise - if you want to see how much it’s holding you back, unbolt it from the down pipe back - and then log.
06-20-2020, 08:04 PM | #13 | |
Rep 7,629
06-21-2020, 12:08 PM | #14 | |
Rep 4,210
06-22-2020, 02:25 PM | #18 |
Rep 7,629
Went back and found the thread:
https://www.3si.org/threads/how-to-b...-stock.708873/ Just read the first post and watch the first two videos. Back to back dyno runs with and without the stock catback in place. It went from 690 to 706 HP.... Of course he had upgraded downpipes and whatnot, just like we do, but the catback was stock. For reference i attached a picture of what the stock catback looks like - its just under 3'' ID, very similar to the F3x stock exhaust, but has tiny tip outlets and its not even a true dual in the sense that its one pipe into the muffler then runs through to the other side. (Its the one on the right, the left is a N/A exhaust) |
06-22-2020, 03:21 PM | #19 | |
Rep 4,210
http://www.superstreetonline.com/how...aust-test-tech Do all of our DP terminate at 3”? |
06-22-2020, 05:00 PM | #20 | |
Rep 7,629
Ill take a look at that article a little later, it looks like they are claiming some bigger HP gains by sizing up the exhaust (notably at 600+whp level as well). I would suspect they were running a bigger DP than exhaust, which might be why the exhaust was proving to be such a restriction. For our platform, the only DP i am aware of that is >3'' at the catback is the CG precision, and they specifically offered a DP with a 3.5'' outlet to pair with their 3.5'' catback. I am not sure if the kits like speedtech offer a custom DP for a larger diameter exhaust. I think the only way you would see any significant gains from going bigger on the exhaust for our platform is if you had a catless DP that was 4'' at the turbo (EWG), and then continued to be 4'' or maybe down to 3.5'' at the catback, then maintained that same size all the way back. To my knowedge this doesn't exist in off the shelf parts (I think CG precision is only catted, and i have not seen a single person running their 3.5'' exit option paired with a 3.5'' exhaust). Using a DP that is 3'' at the catback then running a 3.5'' or 4'' exhaust is probably going to be negligible gains over the same DP with the OEM exhaust. |
