06-09-2020, 10:59 PM | #1 |
Rep 15
2015 435i w/ 65,000 miles - What to replace?
What's up guys. I've racked up about 65k miles on my 435i GC. Just recently flashed it to MHD stage 1, so I know I need to upgrade the charge pipe as soon as possible. Anything else you guys would have replaced?
I heard water pumps usually give at about 80k, so I'm thinking about that. Also looking at the VRSF intercooler. Any input is appreciated. Thanks! |
06-09-2020, 11:47 PM | #2 | |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
06-09-2020, 11:51 PM | #3 | ||
Rep 5,410
imperfectluck434.00 |
06-09-2020, 11:53 PM | #4 | |||
Rep 5,410
06-09-2020, 11:53 PM | #5 | |
Rep 7,632
06-10-2020, 08:54 PM | #6 | ||
Rep 78
06-10-2020, 10:18 PM | #7 |
Rep 15
Just got my car back from the mechanic. I asked him if it was necessary at 65k and he told me to start thinking about it at 80k
All in all I got my brake fluid changed, had the transmission oil drained and filled, and an oil change for $440 out the door. |
06-10-2020, 10:32 PM | #8 | |||
Rep 790
definitley replace this part, mine snapped too and there is a whole thread of people that this has happened to if you search the forum for "PSA". part cost me like $40 at the dealership, but will cost you less online if you do it as preventative.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-10-2020, 11:19 PM | #9 |
Rep 7,632
Just drained the trans without replacing the pan? Are you manual or uato?
06-11-2020, 12:09 AM | #11 |
Rep 790
I think the pan has the filter integrated into it, places like fcp euro sell a kit that comes with fluid and pan. but I'm a 6mt guy, so their may be more to it.
06-11-2020, 01:00 AM | #12 |
Rep 7,632
06-11-2020, 06:41 AM | #13 | |
Rep 5,410
A BMW automatic transmission service is a lot more expensive because the parts are more expensive AND because the procedure is more than just drain and fill. Maybe/hopefully he said that he did the transmission and didn't really do it. If you just drain and fill this transmission it could be underfilled which could ruin the transmission. IMO I wouldn't drive the car until you talk to him and find out exactly what he did or didn't do with your transmission. The procedure calls for actually running the engine while it's on the lift and measuring the temperature of the transmission fluid during the fill process. See the newtis website for details. The service calls for replacing the transmission pan and filter. See photo for ZF service kit. ZF makes the transmission for BMW. Check BimmerShops website for local BMW mechanics. Call and see what they would charge for an automatic transmission service. |
06-11-2020, 06:58 AM | #14 | |||
Rep 5,410
I personally would do it more often. It's a very easy suction and fill service that can be done at the same time as an oil change. It takes only 1 liter of fluid. I wouldn't let a mechanic use just any fluid- only the exact BMW Fluid. BMW sells several differential fluids and part numbers have changed. FCP Euro sells the BMW fluids. If you have an xDrive, the front differential takes 1/2 liter of its own fluid and the transfer case takes 1 liter but only about 1/2 liter can be suctioned out at a time. Both of those take a little more labor to remove bottom panels to gain access. |
06-11-2020, 08:58 AM | #15 | |||
Rep 10,394
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
06-11-2020, 11:43 AM | #16 |
Rep 237
Nothing is lifetime. My rear diff fluid looked like hell at 23k when I sucked it out. Why it looked like crap, and whether or not it would have gone 100k miles we could guess all day, but I personally sleep well at night knowing my fluids are clean and changed and I've done every bit of preventative maintenance one could do. To each their own however, and not everyone's financial situation is the same which can also guide opinions and practices
BoyOhBoyyy17.00 |
06-11-2020, 02:27 PM | #17 |
Rep 15
My mechanic told me he just did a drain and flush because he didn't think my car needed a flush at this time. He's BMW only mechanic if that means anything.
Hopefully he didn't mess my baby up.... |
06-11-2020, 02:48 PM | #18 |
Rep 237
I assume you meant to say he did a drain and fill, you don't flush these transmissions. That's fine, drain and fill is 7ish quarts. The pan is the filter assembly and magnets though. I would have changed the pan at your mileage personally. You could still have him do that, since the total capacity is somewhere around 14 quarts, if you go back and have him do the pan then you'll have put 14 quarts and the filter in and can call it a day. Up to you of course
06-11-2020, 03:01 PM | #19 | ||
Rep 7,632
Assuming he followed the proper procedure for the fill and whatnot (and fluid is therefore at the correct level) then he probably didnt mess anything up... but he basically did half the job without doing the pan/filter. If you go back and do the pan now, of course refilling with fluid following procedures, then you should be good and will have likely gotten even more "new" fluid in since you will have essentially drained twice, and you never get all the fluid out when you do a pan and fluid refill. Quote:
06-11-2020, 04:27 PM | #21 | |
Rep 10,394
All diff fluid looks like crap. It's diff fluid after all. Do whatever you feel like doing.
