Whats your rail pressure on cold start?
06-10-2020, 03:46 PM | #1 |
Rep 57
I'm having a really rough cold start and my rail pressure on cold start is from 75 to 80 and lpfp reads from 72 to 80. Is that normal to be that low on cold start till it warms up? I guess I should mention it's a 2007 and still has a full bank of index 1 injectors and other bank is 12
06-10-2020, 05:13 PM | #2 |
Capt. Maverick
59
Rep 295
Drives: 89 E30 325is, E92 335i N54
Those numbers are ok, normal pressures are around 5-6 bar at operation temp. Pull the spark plugs out before a cold start and see if they are fouled from a leaking injector.
06-10-2020, 06:23 PM | #3 |
Rep 57
Ok I'll give that a try I pulled them just now and I found one that had some oil on top of the plug I might have spilt it in there. If it's a leaky injector there will be fuel on the end of the spark plug?
06-10-2020, 06:28 PM | #4 | |
Davy Jones, Giant Squid
271
Rep 913
If the plug tip looks wet and smells of fuel then its a leaking injector
2010 e90 335i LCI - xHP - Mishimoto - BMS - CPe - Turbosmart - MHD - Eibach - Koni - VMR - LUX
06-10-2020, 07:23 PM | #6 |
Rep 1,200
That could be from the valve cover leaking into the spark plug tubes and when you pull the plug it gets coated. I had a leaking VC and had oil all over my spark plugs so when I went to test for a leaking injector I couldn't tell if it smelled like fuel or oil due to that
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
06-10-2020, 07:36 PM | #7 | |
Rep 57
06-10-2020, 11:04 PM | #8 |
271
Rep 913
Though the OP said the threads were dry.....In that case if it was leaking it would be on the threads and the tip of the plug.
Did you pull all the plugs? How many were like this?
06-10-2020, 11:29 PM | #9 |
Rep 57
Ya sorry I mean like the threads of the plug are dry I just ment see if more oil leaks into the tube where the coil meets the plug. Cuz as far as i could tell no oil made it past the plug, it was only on the top of the plug and the bottom of the coil pack. And i pulled all of them and it was only one that had oil in it. I know the tip was dry cuz I cleaned the oil out before removing the plug so I could tell if it was also in the cylinder.
06-11-2020, 11:46 AM | #10 | ||
Rep 1,200
2009 BMW 335i 6MT
06-11-2020, 10:14 PM | #11 |
Rep 57
Ok well I got the valve cover off today it looks fine and so does the gasket but I got a replacement anyway it was only like $40. And checked my plugs again and they were still dry but there less than a month old and all of them have like really bad black carbon build up on them. That cant be normal right? Is that a rich problem? I do have O2 codes but they are post cat so as far as I know they only test the cat efficiency and dont affect air fuel but also I dont really know.
06-12-2020, 02:01 AM | #12 |
Rep 884
Well after doing the valve cover, how does the car run now on a cold start?
If it's the same then let it sit overnight and in the morning pull out the spark plugs one ata time again and look at the tips where the electrode is. If the spark plug is wet and it smells like fuel then you have a leaking injector.
2013 335is - sold
2011 335d |
06-12-2020, 06:28 AM | #13 | |
Rep 3,219
mweisdorfer1908.50 |
06-12-2020, 09:44 AM | #14 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
At idol, 700 something. All index 12.
