06-13-2020, 09:56 PM | #1 |
Rep 6
Drives: Bmw 330i xdrive
Light malfunction message 2020 330i xdrive
Right front light malfunction message just showed up when i started the car but everything seems to be working fine so should i be worried
06-13-2020, 11:03 PM | #2 |
Petrolhead
1949
Rep 3,521
Since the lights work, did you try turning the car off and back on again? Did the error disappear?
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
06-14-2020, 12:59 AM | #3 |
Rep 6
Ya the message did go away after i turned it off and on again but i guess i bugged out because i gave it a wash with a pressure washer a few days ago and wondering if that messed something up
06-14-2020, 01:57 AM | #4 |
Petrolhead
1949
Rep 3,521
That ideally shouldn’t cause problems. I’ve pressure washed mine many times and never had any issues. Did you clean the engine bay too?
Current:
06-14-2020, 02:37 AM | #5 |
Rep 6
Nope i didn’t clean the engine bay i just did a quick exterior wash for the first time honestly. I didn’t expect the washer to cause any problems either since it supposedly puts out around 1500 psi, unless would that be a bit too much for a car?
06-14-2020, 10:34 AM | #6 |
Petrolhead
1949
Rep 3,521
It could be the pressure washer but I think there’s an increased probability that it was just a random error that hopefully won’t pop up again. If you have an obd scanner, scan and see if error codes are present?
Current:
06-15-2020, 12:02 AM | #7 |
Rep 6
I hope its not the pressure washer, what psi is your washer running at? I wish I had a scanner but that’s probably true it may have just been error message because it hasn’t popped up ever since
06-15-2020, 12:08 AM | #8 |
Petrolhead
1949
Rep 3,521
Karcher pushing around 2000 PSI. Zero issues so far.
Current:
