06-16-2020, 01:20 PM | #1 |
Rep 206
Is it ok to unplug JB4 to plug in THOR wifi and do update?
As mentioned in the title, are there any problems or other steps needed to protect the tune? I don't have the Bluetooth connection. Thanks!
2016 BMW 435i M-Sport
- JB4 and MHD - xHP - Injen intake - Active Autowerke intercooler - Active Autowerke charge pipe - AWE catback *** I want more!!!*** |
06-16-2020, 01:36 PM | #3 |
Rep 206
The jb4 firmware. I also have the xHP tranny tune id like to finally flash lol
06-16-2020, 01:41 PM | #4 |
Rep 462
Leave the JB4 plugged in to do the JB4 firmware update.
Anytime you are flashing and have JB4 its advised to put the JB4 in map 0. Then pull the obd connector. Do your flash. Leave the car off a minute. Then reconnect the JB4 obd connector. Then start the car and put the JB4 back to your preferred map. You cannot update JB4 with thor to my knowledge. I would definitely recommend the JB4 bluetooth kit. It's like 30 buck and allows so much more functionality and convenience. It's just a couple of clicks to update firmware vs connect to the JB4 directly. Last edited by 435gc; 06-16-2020 at 02:02 PM.. |
06-16-2020, 01:55 PM | #5 | |
Rep 206
06-16-2020, 02:04 PM | #6 |
Rep 462
Yeah battery charger is a good precaution with the initial flash. After the initial it's not necessary for map changes as they are only a minute or 2 tops.
Also its recommended to drive the car moderately in a mix of traffic conditions for the first 50 miles after the trans flash. |
06-16-2020, 02:41 PM | #7 | |
Rep 7,629
IIRC they say to remove the JB4 completely, although it may not be necessary and is just a precaution. |
06-16-2020, 02:44 PM | #8 | ||
Rep 206
06-17-2020, 07:49 AM | #10 | |
Rep 206
