06-16-2020, 08:52 PM | #1 |
Rep 150
How much drone with Fabspeed exhaust?
From all the audio clips I've listened to, I like the sound of the Fabspeed muffler bypass best. But, I keep reading that it causes drone. Just how bad is the drone? Can you still talk to your passenger or on the phone when the drone is present?
2013 335i xDrive BMS Intake / VRSF Charge Pipe, Outlet Pipe, 5" Intercooler, High Flow Catted Downpipe / Dyno Tune
2020 M340i xDrive
Dravit Grey Metallic Modifications July 23rd - Dyno Tune |
06-17-2020, 12:36 AM | #3 |
Rep 790
also, if you're going to do a muffler delete, VRSF has one for half the cost of fabspeed, and a muffler shop can do it for less than half to price of that.. if you're spending $900, I would be looking at some of the axle or catback options because yiu're almost there @ the $900 fabspeed price tag.. if you like loud, reasonably priced, and little drone, look @ the Borla ATAK.. it has a multicore resonator that's job is to reduce drone, so their marketing video says at least.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-17-2020, 10:28 AM | #4 |
Rep 150
Yes, the muffler delete. I have not heard one in person...
2020 M340i xDrive
06-17-2020, 10:31 AM | #5 | |
BimmerPost Supporting Vendor
24492
Rep 191,487
06-17-2020, 10:38 AM | #6 | |
Rep 150
How loud are these cars without a muffler? I don't want to piss off neighbors too much.
2020 M340i xDrive
06-17-2020, 11:18 AM | #7 | |
Rep 7,633
I can guarantee you can find videos of catted DP + muffler delete, both with and without resonator. Yes comparing videos is not ideal because of different mic/sound quality, but it gives you an idea. Another way to think about it is the muffler delete is going to be louder, more drone-y, and less refined of a sound than the equivalent DP+resonator setup with any exhaust, including some of the loud aftermarket ones. And i would also echo what is said above that the fabspeed muffler delete is super overpriced for just a small section of straight pipes. |
06-17-2020, 01:43 PM | #8 | |
Rep 150
I found this video and it doesn't seem ridiculously loud. I've had more than one Camaro with high flow cats, resonator, and strait pipes. Here is my last one on a dyno. Even that car wasn't extremely loud when just cruising. I know it's not the same as my 335i, but again, I have never heard this car in person without mufflers. I wouldn't have a problem buying a catback exhaust, but I have often heard they typical drone in these cars anyway.
2020 M340i xDrive
06-17-2020, 01:56 PM | #9 |
Rep 7,633
That video does not sound very loud at all. I would wager its stock DP (there is a comment about him running the sport cat, but i doubt its in that video, because its so muted and there is no turbo noise). Again mic is a huge factor in video/audio.
A aftermarket catted DP will be louder than OEM DP, but having any kind of cat in place and keeping the resonator will help a little. Its not going to be as loud/raspy as catless with resonator delete (full straight pipe), so it might be liveable. |
06-17-2020, 02:17 PM | #10 |
Rep 150
I guess I could always just cut off the muffler and see what it sounds like.
2020 M340i xDrive
06-17-2020, 02:24 PM | #11 |
Rep 7,633
True, because this is what you have to do to install it anyways. Just make sure you cut it at the right spot, and that the exhaust exit is not in a dangerous position like pointing at gas tank or something.
06-17-2020, 03:46 PM | #13 |
Rep 150
What exhaust do people recommend that does not have any drone?
2020 M340i xDrive
06-17-2020, 07:05 PM | #14 |
Rep 5,410
Drives: 2015 BMW 335i x-Drive Auto
If you already have a catted downpipe and stock midpipe, the best sounding axle-back is the AWE.
https://www.kiesmotorsports.com/coll...1994227?aff=22 Below is an installation video. (He subsequently went back to the stock midpipe because the AWE midpipe was too loud for his neighbors |
Kaps335i53.00 |
