06-17-2020, 08:48 AM | #1 |
Rep 12
Engine Oil Level Not Updating
Hey Guys I have a 2013 335i Sedan and I drive pretty hard so i monitor my oil weekly. It's been little over 1000 Miles since my last oil change and Slowly over the course of that time frame The levels dropped. Probably 2 weeks ago it was one Tick above minimum. The message never popped up without me actually going into iDrive and measuring the oil but today I pulled into work measured it and it told me to add a quart so I pulled my Liqui Moly 5w-40 Out Of the Trunk and added the entire thing. I turned the car right back on and measured it and it still says Minimum.
I then drove maybe 4 Miles for a total of 10 Minutes not accelerating hard and measured it again and still nothing. The indy i usually go to was closed so I called an SA at the dealership. He said sometimes you need to add 2? This didn't really make sense to me since it's not like i've been driving with it low this entire time but i added it's as soon as I found it was low. And I don't want to overfill it. Is there a certain amount of time it takes to update? Did I do something wrong? Should I have added half a Qt Instead? Do I really need to add another? P.S There is no leaks, my last oil change was actually when replacing OFHG And Oil Pan Gasket. |
06-17-2020, 09:37 PM | #2 |
Rep 790
that happened to me before. checked from the iDrive and then I started getting the warning, where before it had prompted me automatically. so I stop by autozone and grab 2 qts, was going to save one so I'm covered again in a few months if needed. I dump 1 qt in and drove home, then checked the iDrive again and it was still at the "min" level saying to add a quart, after adding that quart I measured again and it showed at "max". I don't have any leaks either, so you really might just need another qt, I did. and just keep a qt handy and check 1-2 times a month, that's what I do now.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-17-2020, 10:11 PM | #3 |
Rep 2,379
Oil level measuring is SHIT to say it nicely. I never check mine just add a liter when car is telling me.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
06-17-2020, 11:13 PM | #4 |
Rep 790
how do you know when to add it if you don't measure? wait until you hear the lifters ticking? lol
06-17-2020, 11:23 PM | #5 |
Rep 7,632
How many miles are you your cars? I change my oil once a year, which is about 6k miles. I drive the car pretty hard, including long WOT pulls to 160+ mph, with FBO and stage 2+ tune... I check my oil about every 1k miles and even the last check right before i change it at the end of the year, its still full. So i have also questioned how accurate it is. Really wish we had a good 'ol dipstick.
06-18-2020, 12:04 AM | #6 | |
Rep 790
06-18-2020, 12:14 AM | #7 |
Rep 7,632
Yeah, ive seen alot of posts about some oil consumption being normal. Ill just take it that i am lucky and the PO didnt beat on the car too much. I did buy CPO single owner with all maintenance history and am only at 45k miles.
06-18-2020, 10:31 PM | #8 |
Rep 2,379
Thank God the BMW engineers are smarter than you are :P
(A Dane in China) Last edited by harkes; 06-18-2020 at 10:42 PM.. |
06-18-2020, 11:00 PM | #9 |
Rep 790
but what happened to both OP and me is the car DIDN'T tell us anything, and by that time we were down 2 qts.. I had no warning (!) or notice on my iDrive until after I did it manually through the settings, but the time before that it popped up by itself.
06-19-2020, 12:35 AM | #10 |
Rep 2,379
OK. That sound weird. This has always worked for me. How do you know you were 2 qts low?
(A Dane in China) |
06-19-2020, 01:58 AM | #11 | |
Rep 790
06-19-2020, 05:27 AM | #12 | |
Rep 2,379
(A Dane in China) |
06-19-2020, 11:04 AM | #13 |
Rep 1,827
If it's still reading low after adding a quart, my next step would be to add half a quart and recheck. Overfilling can cause a big issues.
Another option, if you have BimmerLink, is to use the oil sensor level readout. I've found that at rest on a level surface, the sensor value sits around 70-75mm when full. To me, that's easier than running the car to the narrow temperature range the oil needs to be in for the car to complete the measurement process in iDrive.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
06-19-2020, 11:06 AM | #14 |
Rep 12
UPDATE: Apparently the engine just needs to cool off and warm up again. I was so panicked because i didn't want to drive with low oil. But after letting it warm up and driving home i checked it again and it Updated. Seems like if you add oil while it's hot it won't update right away.
Rebound152.50 |
10-25-2020, 08:47 PM | #15 |
Rep 15
Drives: 2013 F30 335iX
Engine Oil Level Sensor Always Reading MAX
Hey Guys,
I have a 2013 335iX. The car has roughly around 45k km's. When I go to measure my oil level, the idrive is constantly reading MAX. I do the oil changes myself approx every 6000km. Last oil change I put 6.5L in to start off with as what I found was recommend by the dealer and some videos. Throughout the whole 6000km sequence the oil level constantly read MAX, but when I went to change it, it was at roughly 5.7L. Any sujestions as why it may not be working or what I can do to fix it. I recently changed the sensor thinking maybe it has gone bad but doesnt seem to be the case because it is still reading MAX even through I am 3000km into this oil change run. All help is appreciated. I am running out of ideas as to where the problem may be! |
10-25-2020, 08:59 PM | #16 | ||
Rep 12
you're fine bro everything's working correctly, it only drops down in increments of .25 having 5.7L of oil is more than .75 of the top quart. So that hasn't triggered the dipstick reading. to drop |
10-25-2020, 09:29 PM | #17 | |
Rep 15
I am new to BMW's, I dont know to much about how this system works. |
10-25-2020, 09:55 PM | #18 | |||
Rep 12
CPRO7231.50 |
10-26-2020, 09:49 AM | #20 | |
Rep 15
