06-24-2020, 10:36 PM | #1 |
Rep 19
2015 F30 328i Drivetrain Malfunction
Was at a red light and felt the car began to shake. When I looked down, the car shut off and I received the error code. I turned the car back on, filled up the gas tank (was at 15 miles till empty at the time), drove the car slowly back home and called the dealership.
I'm thinking it might be the spark plugs but we shall see... RIP to my wallet
joshh-o0o-whaaa
06-25-2020, 12:59 AM | #3 | |
Rep 19
Thought that's why the community was here, for support. Thank you for your enlightening response though 🙃 lol
joshh-o0o-whaaa
06-25-2020, 02:06 AM | #4 | ||
Rep 790
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-25-2020, 03:01 AM | #5 |
Rep 909
Drivetrain malfunction could be a million things is what he's trying to say. Pulling codes or going to an indy if you're out of warranty will save you a lot of money.
06-25-2020, 10:42 AM | #6 | |
Rep 7,633
My recommendation is get something to pull codes, whether its a cheap bluetooth OBD2 dongle and a free app, or a dedicated scanner, etc. Going into the dealership blind is the least cost effective way to solve a problem |
06-25-2020, 10:47 AM | #7 | |||
Rep 19
you have a way of scanning for codes? bimmerlink, mhd, bm3, or an actual scanner? I think autozone will scan your car and tell you the codes. and it's hard to say if it's your plugs without codes.. could also be a vacuum issue, a sensor, fuel pump/pressure, maybe vanos related, who knows, the list can go on without codes to narrow it down.[/QUOTE] I don't have a scanner. I haven't changed the spark plugs, and reading that they're supposed to changed about every 50k miles, mine are overdue. So I'm hoping it's that. I took in the car this morning, we'll see what they say. Thanks for the heads up
joshh-o0o-whaaa
06-25-2020, 11:49 AM | #8 |
Rep 841
Drives: Bmw 335i f30 N55 ( sold)
This happen to me before I was bolted on and it was a coil. Super easy to install. But like everyone else said we need more info to help you. Is your car under warranty?
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
06-25-2020, 11:52 AM | #9 |
Modder of everything I own
147
Rep 491
I don't have a scanner. I haven't changed the spark plugs, and reading that they're supposed to changed about every 50k miles, mine are overdue. So I'm hoping it's that. I took in the car this morning, we'll see what they say. Thanks for the heads up[/QUOTE] Good luck, as mentioned above there are many causes for this, just ask me lol.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
06-25-2020, 11:52 AM | #10 |
Rep 19
Update:
So I got the call back and they said it was the fuel pump. However they're advising to change the fuel pump and the EKPS. Total to replace both is about $2,000 Should I go somewhere else? Any suggestions on how much time frame I have before really having to replace them? Appreciate everyone's feedback
joshh-o0o-whaaa
06-25-2020, 12:07 PM | #11 | |
Rep 7,633
IMO i wouldn't pay $2000 for that... but we have no additional information to help determine if that is the correct diagnosis. How did the car drive when you took it to the dealer after refilling gas? |
joshhwhaa1.00 |
06-25-2020, 12:12 PM | #12 | ||
Rep 19
They stated EKPS is about 7/10 that it doesn't need to be replaced, but it is advised. They said the heat made the fuel pump go out lol When I drove it this morning, it seems to be running fine. Power was there, no shaking, no turning on/off, etc
joshh-o0o-whaaa
06-25-2020, 12:47 PM | #13 | |
Rep 7,633
No way i would do the EKP, seems like they are just trying to sell you that. |
06-25-2020, 12:50 PM | #14 | ||
Rep 19
They did run the diagnostic and got an error on the fuel pump though. So I'll probably just get that to be on the safe side and then buy a scanner for future usage. Thanks a lot for everything man
joshh-o0o-whaaa
