06-25-2020, 12:42 PM | #1 |
Rep 57
Which control arm is this
2013 BMW F30 ActiveHybrid 3 RWD. So I was driving on the freeway and when I went over a bump/dip, my car would steer side to side, fishtailing on the freeway. When I got home I jacked up the car and found a snapped control arm. I called BMW and they told me there were 4-5 control arms in the rear, and I was unsure which one I needed.
I looked at realoem, and me not knowing too much about suspension, couldn't decipher the differences in which control arm is which. Can someone tell me which rear control arm I need to purchase? This is for the rear right side. Also, does anyone have any torque specs for how tight this should be? Thanks for the help! Last edited by chriscruz7411; 06-25-2020 at 12:47 PM.. |
06-25-2020, 12:59 PM | #2 | |
Rep 5,413
Drives: 2015 BMW 335i x-Drive Auto
Get under there and clean off the broken part. There are numbers on the casting that should help to identify it |
06-25-2020, 02:11 PM | #4 | |
Rep 3,549
It's kind of hard to tell which arm it is since the photos only show the arm and not where the arm is in relation to the rest of the rear suspension.
That said, I'm guessing it's your rear trailing arm. If it is that part it's pretty easy to replace on your own and you can check out my video below for an overview of the control arms and how to replace the one you need (including torque specs). The video description (on Youtube) also has part numbers. Quote:
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
06-26-2020, 09:03 AM | #5 |
Rep 320
wow! was there any other damage? I would have never guessed that trailing arm would break that way...crazy
06-26-2020, 11:42 AM | #7 | |
Rep 57
06-26-2020, 12:59 PM | #8 | |
Rep 3,549
