07-01-2020, 10:10 AM | #1 |
Joint Chiefs of Staff
24359
Rep 191,163
Burger Tuning (BMS) B58 Oil Catch Can Now Available W/ Free Shipping!
http://www.extremepowerhouse.com Why shop with us? Lowest Price Guarantee: We do our best to always have the lowest price on our website, but if you found an even lower price somewhere else let us know. We will match the other price and thrown in an extra $25 store credit towards your next purchase. Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval. Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/ Hours: We are open 7 days a week from 8 AM to 11 PM Pacific Time. Contact us: For any questions you can pm / email Mike@x-ph.com or call 725-221-5267. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours. Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality. Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 725-221-5267 and we can process your order over the phone. Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options. Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location. XPH Rewards: We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends. Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales. Attachment 1750313 Order Link https://store-gd6olw6.mybigcommerce.com/burger-tuning-oil-catch-can-n55-b58-s55-s63tu/ Keep Oil Out of your G20 B58 BMW Air Intake System! It's no secret that BMW turbo motors can suffer from oil control problems causing the oil to blow through and coat the intercooler and charge piping, gunking up intake valves and the VANOS system, lowering the effective octane, and generally degrading engine performance. The higher your boost levels the more apparent these problems become. The solution to this problem has finally arrived. The BMS oil catch can. While there are other catch cans on the market they all fall short in various areas. Some are mounted on the hot/turbo side of the motor preventing proper vapor condensation. Others utilize hoses that are too small and runs that are too long to allow proper PCV ventilation causing internal motor/ring sealing issues. Some have insufficient or no internal baffle system while others have internal baffles systems that are too restrictive. Some even bypass the PCV system all together venting crankcase gas and odor to the atmosphere. Most are simply repackaged oil catch cans from smaller / lower power motors shoehorned into place in the turbo BMW engine bay. To solve these problems BMS designed their oil catch can kit from the ground up specifically for the turbo BMW application. It features 100% CNC machining with zero welding for a precision fit and long life. The can itself is guaranteed for the life of the vehicle. The hoses exceed the OEM PCV piping in diameter and that flow rate is maintained throughout the entire oil catch can ensuring no excessive crankcase pressure buildup. The BMS OCC retains the factory fully closed loop PCV operation preventing any PCV vapor from leaking to atmosphere. The mounting locations are selected to minimize the line length, allow more efficient operation, and retain a stealth look. Install takes around 20 minutes, includes all required hardware, and is 100% reversible. Simply unscrew the base of the can or use the drain plug to safely dispose of captured oil with the rest of your used motor oil during oil changes. Made in the USA. FEATURES AND BENEFITS • Increases Air Intake Efficiency • Promotes Engine Longevity • Non-Clogging Air/Oil Separation Double Baffle • Free Flow Solid No Restriction Design • Retains factory fully closed loop PCV operation • Large Intake/Outlet No Tapering Down • Anodized Black Aluminum • Made in the USA & Guaranteed for Life • Simply unscrew base every 3-6 months to empty or use the 1/8th NPT drain plug. • Non-Clogging, No Service Needed Air/Oil Separation Double Baffle • High flow to eliminate crankcase pressure caused by more restrictive designs • Large 16mm+ inlet and outlet exceeds OEM PCV sizing • Precision CNC Machined from Solid Blocks of High-Grade Aluminum APPLICATIONS BMW 3 Series • 2019+ G20 (B58 engine) M340i and M340iX KIT INCLUDES (1) BMS N54 Oil Catch Can (1) Billet B58 bracket (1) 90º billet fitting/nipple (1) Custom Silicone inlet hose (1) 3.5" Straight hose (2) Stainless steel bracket screws #10-32 x 1/2" internal hex socket head Kit for factory intake includes the BMS B58 intake muffle delete DIMENSIONS Can dimensions with lid: 4.4" (111mm) Tall Can Diameter: 2.7" (68.5mm) Lid Length: Back to nozzle end: 4" (101mm) Nozzle Outer Diameter: .75" (19.2mm) Nozzle Inner Diameter: 0.669" (17mm) Can Capacity: 2.5 oz (74 ml)
12-20-2020, 01:31 PM | #2 |
24359
Rep 191,163
08-15-2023, 08:18 AM | #3 |
24359
Rep 191,163
09-04-2023, 08:44 AM | #4 |
24359
Rep 191,163
09-26-2023, 09:01 AM | #5 |
24359
Rep 191,163
10-20-2023, 09:13 AM | #6 |
24359
Rep 191,163
12-15-2023, 11:09 AM | #7 |
24359
Rep 191,163
01-22-2024, 09:19 AM | #8 |
24359
Rep 191,163
02-01-2024, 08:40 PM | #9 |
Rep 101
Drives: 2023 m340i xdrive
Hey how much for the catch can?
02-01-2024, 08:58 PM | #10 |
24359
Rep 191,163
03-14-2024, 08:51 AM | #11 |
24359
Rep 191,163
