Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Where is the negative jump start connector?
      07-12-2020, 12:22 PM   #1
newway
Drives: BMW 320i M SPORT
I am looking at the car manual and it indicates a 'special connection on the body'
serves as negative.
However when i open the bonnet i can't find such 'connection'
indicated by the manual picture, there should be a connector in the
rectangle i marked, but there is nothing there?
anyone know where the negative connector should be then on a g20 320i?
many thanks
      07-12-2020, 12:36 PM   #2
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
serves as negative. However when i open the bonnet i cant find such 'connection'
In the photo you attached, the aluminum stud with the black wire connected to it, up and to the left of the area you identified.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
drexplode1790.50
      07-12-2020, 01:41 PM   #3
Yossi123
Drives: 330xi G21
Had the same problem and I can confirm the stud with the wire, that's the connection I used.
      07-12-2020, 01:48 PM   #4
MDG
Drives: 19' G20 - 330i, 18' F20 - 120i
Also had the same problem. SA told me to connect the negative connector on the stud, as agreed by others above. In my car, the wire is brown. Hope this helps.
      07-12-2020, 05:03 PM   #5
newway
Thank you very much!
g20
