BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Emergency Call Error - Permanently On Screen
      07-15-2020, 10:09 AM   #1
jedpause
jedpause's Avatar
Drives: G20 330e M Sport '21
Hi all, I did search this forum, could find a similar thread...
This week I got an error pop up on my dash and in my My Vehicle Messages along the lines of "Warning - Cannot Make Emergency Calls" and when you drill down it says contact your technical blah blah...
Even once I open it, it still takes up all the space on the centre of my dash where I normally would see Miles done - free and other telemetry - what a pain...
I suspect it is the TCU or TCU battery (seen that reported on older forums), or maybe a subscription expired?
Anyone know how to get rid of the warning, and if it does need an engineer fix?
TIA
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud
Alpine White F10 M Sport - Gone to Stud
      08-16-2020, 07:02 PM   #2
Zeezu541
Drives: F20 M140i || M3 F80|| F90 M5
TIA
Still looking for a fix
I know the solution
      08-17-2020, 02:49 AM   #3
jedpause
jedpause's Avatar
I know the solution
I am taking it for service October, but if you can tell me what to do in the meantime, that would be appreciated!
      08-17-2020, 03:53 AM   #4
Zeezu541
I know the solution
Do you have access to esys
      08-17-2020, 07:30 AM   #5
mrgicm
mrgicm's Avatar
446
Drives: BMW M
If you have warranty they will replace your TCB due to faulty battery, or you can code out the SOS call and the error will be gone, however it will not work anymore.
      08-18-2020, 06:34 PM   #6
suhaib_dost
Drives: BMW G30 520D
TIA
Happend to me but that was because i had the panel removed from under the passenger dash, some sort of antenna connects into there
      08-20-2020, 07:43 AM   #7
jedpause
jedpause's Avatar
As in can I do coding? No I can't, was hoping to solve it without that method
It seems I will have wait until October for BMW to replace parts etc
      08-21-2020, 12:09 PM   #8
hlothery
Seeking mental floss
482
Drives: 2022 Mercedes EQS 450+
The cause is battery failure, the battery is in the headliner near the antenna. It must be replaced if you want the emergency call system to continue to work. Dealer did mine under warranty.
clee1982797.50
      08-30-2020, 05:57 AM   #9
Zeezu541
It's a literal 5 minute fix on esys but it will only remove the warning not the problem
      09-07-2020, 02:19 AM   #10
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3561
Drives: 2024 iX 50 | 2020 X3 M40i
You need a TCB battery under the headliner.
clee1982797.50
      11-29-2021, 06:38 AM   #11
rickkap
Drives: 320d XDrive M Sport (G20)
My brother has just got this message and wants to disable it.
Can you give me the info in esys to remove it from notifications please.
      12-20-2021, 02:55 PM   #12
swatsev
Drives: g30
Hello. please give the coding for esуs For me.
      12-21-2021, 01:53 AM   #13
iwantotlearn
Drives: 520i
Hello,
Using bimmercode do the following:
1. Go to instrument cluster (DKOMBI2)
2. Switch on expert mode
3. Go to 300A - CC_Konfiguration
4. Change the byte no.5(6th byte) value to F7
Done
Th error message will dissapear, idk if emergency call is still available after that tho
      12-21-2021, 03:02 AM   #14
swatsev
Drives: g30
Originally Posted by iwantotlearn View Post
Hello,
Done
Th error message will dissapear, idk what if that emergency call is still available tho
What this 300A?may be 3000?
      12-21-2021, 03:41 AM   #15
iwantotlearn
Drives: 520i
On my car it appears 300A
https://ibb.co/hdQ9k3j
https://ibb.co/dLYBPJ5
Posted links for images as attachment option is giving me some troubles.
      12-21-2021, 05:08 AM   #16
swatsev
Drives: g30
thanks! on f7 to change the sixth byte?
      12-21-2021, 06:46 AM   #17
iwantotlearn
Drives: 520i
Yes, as presented in the picture.
Come back and lavea feedback after
      01-18-2022, 04:11 PM   #18
Wojti_
Drives: BMW F11, G30
Hi,
How to decode error in esys? I have also problem with emergency call not available
      01-22-2022, 01:36 PM   #19
Herki
Drives: BMW G30
Hello,
Done
I try to change it but I can put value only 0X00 or 0X01
How change to F7? Ur photos not working.
      01-24-2022, 05:05 AM   #20
Herki
Drives: BMW G30
Pictures not available
      02-06-2022, 10:21 AM   #21
Herki
Drives: BMW G30
Anyone guys ??
      02-06-2022, 02:52 PM   #22
Biliardiere
Biliardiere's Avatar
Drives: BMW 520d Msport Xdrive G31
Hi
Originally Posted by Herki View Post
Anyone guys ??
What are you looking for?
by mistake of the emergency call I can help you?
5post
