07-17-2020, 06:14 PM | #1 |
Rep 147
G-Plus intercooler Back in stock
Hey Guys,
Just wanted to let you know that the G-Plus intercooler is back in stock on amazon. I just ordered one after reading how many people was satisfied with it and for the price it's a steal. Good luck Only 8 left: Bolt On Front Mount Performance Intercooler Kit For Bmw 1 Series F20 116i / 2 Series F22 F23 / 3 Series F30 F31 / 4 Series F32 F33 Black https://www.amazon.com/dp/B079P8BWYW..._FaJeFb5G79H1X |
07-18-2020, 10:06 AM | #3 |
Rep 136
i bought one a couple of years ago...don't recall any additional parts...
be gentle pulling out the stocker and you should be able to reuse o-rings on charge/inlet pipes... |
07-18-2020, 10:35 AM | #4 |
Rep 1,072
Comes with nothing. Easy install seriously if you have access to a lift or ramps. Getting the clamp off the OEM intercooler is a little tricky until you figure it out. Otherwise easy install in under 20 minutes
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
07-18-2020, 12:55 PM | #5 |
Rep 7,629
Not recommended to reuse the orings. Get new stock, or better yet, read the oring seals for charge pipes thread incase you need to use larger-than-stock orings to get a air tight seal. I would recommend having them all on hand before starting the install.
