SPL Adjustable Front Caster Rod Monoball Bushings BMW F2X/F3X |
07-18-2020, 01:54 PM | #1 |
Supreme Allied Commander
3886
Rep 54,507
Drives: F80 M3
SPL Parts FKS Series Front Caster Rod Bushings (CRB) replace the stock flexible rubber bushings with low friction, articulating Spherical Bearings eliminating bushing deflection and reducing friction. This maintains optimum suspension geometry under load to improve braking and handling feedback. Massive 1" sized FK Racing Bearings with self lubricating Teflon liners are used to ensure maximum performance and durability. Innovative CNC machined offset bearing spacers provide +/- 4 degrees of caster adjustment. OEM arms not included.
Sold as a pair. Made in the USA. SPL Parts Caster Rod Bushings Features: 6061-T6 Aluminum bearing housing with outer knurl 6061-T6 Aluminum offset spacers provide +/-4 degrees of caster adjustment FK 1" spherical bearings Applications: 2010+ F2X 2011+ F3X **Please note these will not fit xDrive/AWD vehicles** Order here: https://www.hpashop.com/products/spl...6dda67f9&_ss=r Last edited by HP Autosport; 10-20-2023 at 07:00 PM.. |
07-07-2022, 01:32 PM | #21 |
3886
Rep 54,507
Drives: F80 M3
Sold as a pair. Made in the USA. SPL Parts Caster Rod Bushings Features: 6061-T6 Aluminum bearing housing with outer knurl 6061-T6 Aluminum offset spacers provide +/-4 degrees of caster adjustment FK 1" spherical bearings Applications: 2010+ F2X 2011+ F3X **Please note these will not fit xDrive/AWD vehicles** |
