07-19-2020, 06:23 PM | #1 |
BimmerPost Supporting Vendor
24477
Rep 191,448
Turbo Transformer Boost Controller. Simple, Reliable & Fun!
I had the chance today to try the Turbo Transformer in my car, and I'm very impressed!
It's a very simple piggyback with only two sensors to connect. It'll take a few minutes to install. One of its best features is Bluetooth capability that allows you to use the TT app to change maps and settings. I took a few screenshots of the app,and I figured i would show you how it works. Setup
Base PSI: This is the PSI level at which the tuner is active. when your boost is below this PSI, the unit is not active and the car is running at stock power Delta PSI: This is the maximum amount of PSI the unit will be adding to stock. Its set to +2 PSI by default but can be increased to +4 PSI (please use with caution) Slope (Rate):
Graph:
Power Modes
Power Default
Max Eco
Hybrid
Custom
07-19-2020, 07:25 PM | #2 |
Rep 841
Drives: Bmw 335i f30 N55 ( sold)
What type of tunes would you say this is comparable too?
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
07-19-2020, 09:05 PM | #3 |
Rep 2,379
A JB+ knock off?
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
07-19-2020, 09:50 PM | #4 |
24477
Rep 191,448
Not even close . If anything it’s more like the dinan sport since the both use the phone app.
That being said it’s not a knock off anything , it’s a tuner that has its own features including the different modes, the ability to turn on/off the unit based on PSI,etc... Please do not make false claims |
07-19-2020, 09:52 PM | #5 |
24477
Rep 191,448
Tpriest7893232.00 |
07-20-2020, 08:50 AM | #7 | |
24477
Rep 191,448
If you have supporting mods and good grade fuel, you will be fine. If you have low-grade fuel and no mods, its probably best to keep it at default power
07-20-2020, 09:15 PM | #8 | |
Rep 2,379
(A Dane in China) |
07-21-2020, 11:16 AM | #9 | |
24477
Rep 191,448
The Turbo Transformer also includes 0-60 times, peak PSI,etc... I don't feel we need to label it a knock-off product, it's just another option with cool features and a great price
07-21-2020, 11:30 AM | #10 | |
Rep 7,629
Do they have one for B58, S58, or others? |
07-21-2020, 11:40 AM | #11 | |
24477
Rep 191,448
We offer 3 BMW units. The first unit fits N20, N26, N55, and S55 The second unit fits B46, B48 & B58 The third unit fits N63 and S63
08-04-2020, 09:19 PM | #12 | |
Rep 48
Why does it have to be a knock off at all? Why can't it be just another product? Otherwise, could you define where this "knock off" chain ends? ... you could say Dinan is a JB knock off; and then JB would be an AEM knock off, and is AEM an MSD knock off? I am saying piggybacks date well into the 1990's
MODS: Turbo Transformer boost controller, ECO-SPORT auto selector (home brew), Electronic boost gauge vent mounted, RPM based LED Carbon paddles
WISHLIST: BM3, HPFP, Turbo + IC + water ... new car eventually |
08-05-2020, 04:31 AM | #13 | |
Rep 2,379
(A Dane in China) |
08-13-2020, 09:03 AM | #14 |
24477
Rep 191,448
08-20-2020, 01:39 PM | #15 |
24477
Rep 191,448
08-21-2020, 06:22 AM | #18 |
Rep 147
08-21-2020, 09:34 AM | #19 |
24477
Rep 191,448
Yes, you can, without damaging any of the stock components.
08-21-2020, 10:05 AM | #20 | ||
Rep 7,629
If you are EWG and running the E20 stage 2+ map, its pretty likely you will crash HPFP even with only +2 psi. Especially true if you are running more than E20 in the tank; i am running E30 in the tank on the E20 map and its more or less at HPFP limit already. If you are EWG and running a pump gas stage 2+ map, you might have some headroom on the HPFP, but unless your gas is excellent quality or you are running boostane, its likely timing will suffer and and you will lose whatever power you were trying to gain with the boost. With a PWG you might not have the HPFP crash concern, but these maps basically already max out the stock turbo anyways so the hardware limitation will be the PWG turbo. If you have an upgraded HPFP on EWG it might be an interesting experiment to say run E30-40 in the tank (extra octane) on the MHD stage 2+ E20 map and use a piggyback to turn up the boost a little in lieu of a custom tune, but the more refined route is obviously to just get a proper custom tune so the DME is controlling everything, the trans knows how much torque the engine is making, and avoid all the other potential 'issues'/considerations of running a piggyback. I suppose you could also do the same experiment if you are spraying meth on a EWG, instead of having HPFP upgrade. |
08-27-2020, 11:06 AM | #21 |
24477
Rep 191,448
JBH661235.50 |
