08-09-2020, 11:22 AM | #1 |
Rep 244
Drives: 2020 BMW M340i xDrive
First Ceramic Coating Installed on my M340i!
Finally got my car after a longer than usual wait (COVID related plant shutdowns right after my order was accepted) and was able to get the car properly detailed and coated this weekend. I started the process by foaming the car and then doing a two bucket wash. Then chemically decontaminated and clayed the car. There were a couple paint defects that I wanted to take care of so I followed the decon up with a light polishing. A quick panel wipe and I was ready to install the ceramic coating, which was my first foray into coatings. I've used sealants and SiO2 enhanced products in the past, but never a true coating. After much research, I ended up going with one coat of GTechniq Crystal Serum Light and two coats of Exo V4 for the coating. I had read many horror stories with ceramic coatings (difficult to install, high spots, hazing, etc.), but thankfully I didn't run into any issues. I did pay a lot of attention to the prep and took my time doing everything, which I think really helped make this a smooth install. In the end, I'm really happy with the gloss and smoothness provided from the coating, and am looking forward to the protection it provides hopefully for the entire lease term. I will definitely be installing ceramic coatings on all my cars moving forward.
Products used: Meguiars Hyper Wash D11001 Meguiars Non-Acid Tire and Wheel Cleaner D14301 McKee's 37 Xtreme Iron Remover McKee's 37 N914 for Clay lube Aquapel Glass Coating Meguiars M205 Lake Country White Flat Pad CarPro Eraser GTechniq Crystal Serum Light GTechniq ExoV4 |
09-04-2020, 11:26 AM | #2 |
Rep 2,056
Drives: '05 M3 6MT
Car looks fantastic! Are you a member of the Obsessed Garage Facebook group, by any chance? If not, you should check it out. I get the hunch that you'd fit right in!
I'm not brave enough to ceramic coat my own cars. I'm barely comfortable correcting paint, so I stick with the tried and true Collinite 845/Jescar Powerlock combo. That said, I think I am going to ceramic coat my wheels and calipers once my M340 arrives. That will be a good first test for myself.
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
themnmd1716.00 |
09-04-2020, 02:27 PM | #3 | |
Rep 244
I was a little worried about ceramic coating as well, but honestly I didn't run into any issues. I think the key to coatings is to spend the time on the prep. I was very meticulous on this job since it was the first time. Took me about 14 hours to clean, polish, and apply three coats of ceramic. I could've went quicker, but i figured it was better just to take my time. I think I was more nervous the first time I took a DA polisher to one of my cars than putting this coating on. At least if I messed up the coating I knew I could just polish it off. The wheels and calipers are the only thing I haven't done yet. By the time I was done with the paint, I was ready to be done. I plan on putting the car on stands and doing the wheels and calipers soon though. I'd say that's a great place to try your hand at ceramic coating. Once you get the hang of it then you can do your whole car. |
09-04-2020, 03:14 PM | #4 |
Rep 2,692
Drives: 23 X5MC
Great job I did mine too. just takes time and patience
09-04-2020, 04:06 PM | #5 |
Rep 156
Looks great!! i'm about to undertake my first detail work on black swirly car... Never done anything like this before apart from using normal wax but i'm sick of seeing swirls and light scratches... I don't think i could go all the way and add a ceramic coating just yet. I hope mine comes out looking like yours.
09-04-2020, 11:13 PM | #7 |
Rep 4,668
Looks amazing!
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
09-07-2020, 01:40 PM | #8 |
Rep 1,491
Drives: 2020 M340Xi (G20)
tnsatbhs ,
Looks fantastic!! I didn't have your guts so I got ceramic done by a local respected detailer
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
