08-11-2020, 11:20 PM | #1 |
Rep 38
N55 Dorch Stage 2 Full E85?
Hey guys, I have read so many mixed answers on this one i'm confused.
Can a F32 N55 run full E85 with a dorch stage 2 HPFP with a stock lpfp? Thanks!
'16 435i - CTS Turbo FBO Catless DP,FMIC,CP & Intake / PR Ignition Kit / BM3 stage 2 E30+ / TPC Stage 2+ Hybrid Turbo / Turbosmart Dual Port BOV Black Plumb / Dorch Stage 2 HPFP / Mst V2 Turbo Inlet / xHP Stage 3
08-12-2020, 01:24 AM | #3 |
Rep 38
Correct should have asked the question better
08-12-2020, 08:24 AM | #4 |
Modder of everything I own
147
Rep 491
I'm wondering the same. Still on the fence on the Dorsch or PI. Multiple scenarios including full e85 as you mentioned. For me 650hp, I want to run at least e50 but I don't want to run on the edge of the HPFP capability either.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
08-12-2020, 11:39 AM | #5 | |
Rep 7,633
He ran over 600whp with E40-E50 but he did have meth on top i believe. According to dorsch website, they say 500whp on full E85. I think that's a safe/conservative estimate to leave you with a little more headroom on the HPFP so you dont get crashes if its cold outside or something. I am not aware of anyone here who has pushed over that with a dorsch stage 2 on full E85 so if you dead set on 600+ with full E85 you might be the one to test the limits. I also think that going to 600+ on full E85 might be at/beyond the limit of the LPFP as well. Personally I think that if you want to go full E85, getting the stage 2 HPFP, keeping stock LPFP, and getting a nice safe tune for low 500s whp is the way to go... put less stress on everything, not worry about being at the limit of hardware, and keep engine/trans alive for a long time. Just my opinion though, your car and $$$ |
08-13-2020, 05:30 AM | #6 |
Check out my Youtube @n55david!
1306
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
i have a dorch stage 2.. you can not run full e85 withouth the lpfp becoming a problem.
e70ish, yeah sure.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
BeerHerder250.50 |
08-13-2020, 11:04 AM | #7 |
Rep 7,633
08-13-2020, 12:30 PM | #8 |
Rep 38
Now I am lost, so if you run full E85 and make 475-500WHP will the LPFP cause issues or only bottleneck if you push further?
08-13-2020, 12:37 PM | #9 | |
Rep 7,633
I dont suppose anyone knows the lph rating of the OEM LPFP? |
08-13-2020, 01:03 PM | #10 |
1306
Rep 3,554
no idea.. im at like 20.1 psi
if i dont back off the ethanol to around e70 i will get a fuel pressure crash.. thats after multiple revisions and talking to dorch. seems the lpfp wont support a maxed maxed out system.
08-13-2020, 01:45 PM | #11 | |
Rep 7,633
Do you have any datalogs of trying to run E85 or successfully running E70? It's too bad we dont have a LPFP pressure sensor. |
08-13-2020, 02:24 PM | #12 | ||
1306
Rep 3,554
anything about 6k and thenboost drops hards. like 14 to 15psi.. oem turbo cant keep up. thats with no leaks and a turbosmart diverter. im shifting at 6k to 6200ish tops
08-13-2020, 06:59 PM | #13 | |
Rep 7,633
08-13-2020, 07:20 PM | #14 | ||
1306
Rep 3,554
best i did on e30 was 12.08 or .04 or something
08-14-2020, 03:15 AM | #15 |
Rep 38
Well I don't mind getting a new LPFP. My worries are I heard stage 2 LPFPs causing issues with stock ekp module, to be specific they are fuel-it.. would a spool stage 2 still have this issue? or would just be going stage 3 with a hobbs switch be the best option?
08-14-2020, 09:36 AM | #16 |
Rep 7,633
Generally yeah that tends to be an issue with upgraded LPFP. There is an upgraded EKP available. Forgot the company, but its $500-600 IIRC.
08-14-2020, 01:50 PM | #17 |
Rep 38
will all stage 2 pumps have this issue? I'd rather buy the stage 3 than buy a new EKP..what are the chances a stage 3 pump could fail with a hobbs?
08-14-2020, 01:51 PM | #18 |
Rep 7,633
Wait what? Are you saying you want to get an even bigger LPFP? The issue is basically with the amount of power the LPFP can draw and overheating the EKP.
08-14-2020, 01:59 PM | #19 | |
Rep 38
Stage 3 LPFP(fuel it) from my understanding is a OEM LPFP rebuilt to be fully e85 compatiable with a secondary pump so it takes no additional draw on the EKP unless above 15psi, The secondary pump activates with a hobbs switch at about 15psi. So secondary pump will only be active in WOT I assume. I think that will solve the EKP issue but I am just curious to know if that would be a viable long term solution?
08-14-2020, 02:31 PM | #20 | |
Rep 7,633
