08-12-2020, 01:31 PM | #1 |
Rep 1,492
First phase completed. Looks great, and happy to report that the ride is completely stock. The instructions that come with the links are incredibly thorough and detailed with photos. The local shop had no problem with installation. Thanks Ben for a great product. More photos coming soon.....
1. RG sport lowering links 2. Paint corrected/ceramic pro 3. Tinted reflectors and debadged
2020 G07 x40i BSM/Blk Merino
2022 Audi E-tron S Mythos Blk/Blk Valcona |
08-12-2020, 02:29 PM | #2 | |
Rep 572
How difficult was it to install the lowering links? How low did you go? |
r33_RGSport13036.50 SammiK72.00 |
08-12-2020, 02:31 PM | #3 |
Rep 706
Solid! If that's the loading height that you pictured, you went pretty conservative it looks like?
r33_RGSport13036.50 |
08-12-2020, 03:49 PM | #4 |
Rep 1,246
Nicely done. May I ask how many mm from stock length you went from the originals? I'm getting ready to do the same job, and I've received conflicting reports that recommend anywhere from 2mm to 6mm.
08-12-2020, 05:11 PM | #5 | ||
Rep 1,492
08-12-2020, 05:13 PM | #6 |
Rep 1,492
Overall yes it's a conservative drop but definitely noticeable versus stock. Here is another shot which better shows the new loading height
08-12-2020, 05:19 PM | #7 |
Rep 1,492
Thanks! Honestly can't tell you what the overall difference is versus stock, but it's noticeable. The instructions that come from RG sport are very specific for setting up the links front/rear to achieve this drop. Since the links are adjustable, I assume you could go even lower if you wanted to.
08-12-2020, 05:52 PM | #8 |
Rep 1,492
The instructions from RG say you need to extend the front links to 24mm and shorten the rear links to 16mm to achieve this drop. Since they are adjustable you could likely have a more aggressive drop if you want. I would suggest talking w Ben at RG, he would be able to give you the best insight.
08-14-2020, 12:41 PM | #9 |
Rep 18,747
Luminor513 Looks good.
Thank you for the shoutout.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
jsnkim320.50 |
08-14-2020, 03:23 PM | #10 |
Rep 158
curious, can you drive at the lowered height or is this for parking only?
bsm m4.
r33_RGSport13036.50 T1M3LESS2274.50 |
08-14-2020, 05:10 PM | #11 |
Rep 18,747
You can drive as low as original loading height.
08-14-2020, 09:42 PM | #12 |
Rep 158
thank u sir ! looks great, nice suggestion.
bsm m4.
08-16-2020, 12:30 AM | #13 |
Rep 269
Drives: 2020 G05
Looks sharp!
Enjoying life! Missing the warmth of the 305.
11-27-2021, 11:09 PM | #15 |
Rep 1,492
I drive in sport individual at all times. Much less floaty, but remains comfortable. Really it's the ideal setup for the X5. Those that have complained that the air suspension is too floaty, have not been in one lowered with 22inch wheels. It drives the way one would expect a BMW suv to drive.
11-27-2021, 11:27 PM | #16 |
Rep 1,492
Also if your going to lower yours I would also recommend H&R spacers through RG sport. The overall look with lowering links and spacers is perfect. The way it should have looked from the factory.
r33_RGSport13036.50 C Jasmin11.00 |
12-01-2021, 11:28 PM | #18 | |
Rep 18,747
Thank you for your business.
12-16-2021, 08:05 AM | #20 | |
Rep 293
Here's mine on lowering links and winter set up: |
particulardude379.00 |
12-16-2021, 08:36 AM | #21 | ||
Rep 1,492
