New cooling system saver
08-12-2020, 01:58 PM | #1 |
Rep 2,099
Anyone see this? Just got this in my inbox from ECS:
https://www.ecstuning.com/b-ecs-part...it/004481la01/ I know the aluminum piece has been around from generic vendors for awhile (and ECS's version always cost 3x as much for anything billet). But I did think the silicone tubing was a nice addition -- esp since you'd always have to buy and deconstruct a full piping (with the mount preinstalled) previously. Anyone happen to try it? Also saw Turner has some set-spec camber plates...will post that separately in Suspension section. [EDIT: MODS PLEASE REMOVE IF NOT ALLOWED OR ALTER SO IT DOESN'T VIOLATE ANY RULES -- I HAVE NO ASSOCIATION TO ECS NOR IS THIS AN AFFILIATE LINK. JUST WANTED TO DISCUSS] |
08-12-2020, 02:45 PM | #2 |
Rep 18,825
Seems like a waste of money. OE rubber section of the hose is good enough. Replace with the $20 hose bib and call it a day.
My 2 cents. |
bluewater328626.50 tlow982194.00 |
08-12-2020, 03:09 PM | #3 |
Is it the shoes!?
3885
Rep 5,112
Yeah, the plastic flange is the failure point. Rubber coolant hoses tend not to be the issue on BMWs. You can grab an aluminum flange for way cheap.
08-12-2020, 05:07 PM | #4 |
Rep 2,476
I guess, if you need to replace the hose for whatever reason, that's an OK option. Otherwise, any of the aluminum flange offerings with the stock hose will do.
