08-12-2020, 09:00 PM | #1 |
Rep 589
Anyone can explaine for me the algorithm behind auto start / stop on G05? Under which circumstances that it cuts off the engine and under which circumstances that it start it up again? I am only asking this because I have few instances where it just decided not to cut off the engine even I come to a full stop. And some other instances, it cut off the engine and later it decided to starts it up again without me releasing the brake...
Attached is a picture of the dash board where it decided not to cut off the engine even we are completely stationary. There's white Auto Start / Stop symbol with a line cross it |
08-12-2020, 09:13 PM | #2 |
Rep 20,419
Depending on the air conditioning needs it won't shut off when you stop. Another reason it may not stop is if it detects the car in front of you moving, like at a stop sign. That is also a reason for the engine starting while you still are on the brakes, if the car in front of you moves up at a light the engine will normally start.
08-12-2020, 09:54 PM | #5 | |
Rep 4,487
Auto Start/Stop function The Auto Start/Stop function helps save fuel. The system switches off the engine during a stop, for instance in traffic congestion or at traffic lights. Drive-ready state remains switched on. The engine starts automatically for driving off. Functional limitations The engine is not switched off automatically in the following situations: In case of a steep downhill grade. Brake not engaged strongly enough. The external temperature is high and automatic climate control is running. The car's interior has not yet been heated or cooled to the required level. Where there is a risk of window condensation when the automatic climate control is switched on. Engine or other parts not at operating temperature. Engine cooling is required. The wheels are at a sharp angle or the steering wheel is being turned. Vehicle battery is heavily discharged. At higher elevations. The hood is unlocked. HDC Hill Descent Control is activated. The parking assistant is activated. Stop-and-go traffic. Selector lever position in N or R. After driving in reverse. Use of fuel with high ethanol content. Safety mode After the engine switches off automatically, it will not start again automatically if any one of the following conditions are met: The driver's safety belt is unbuckled and the driver's door is open. The hood was unlocked. Some indicator lights light up for a varied length of time. The engine can only be started via the Start/Stop button. System limits Even if driving off was not intended, the deactivated engine starts up automatically in the following situations: Excessive warming of the car's interior when the air conditioning is switched on. Excessive cooling of the car's interior when the heating is switched on. Where there is a risk of window condensation when the automatic climate control is switched on. When the steering wheel is turned. Change from selector lever position D to N or R. Change from selector lever position P to N, D, or R. Vehicle battery is heavily discharged. Start of an oil level measurement. Intelligent Auto Start/Stop function Depending on the vehicle equipment and country-specific version, the vehicle features a variety of sensors for assessing the traffic situation. The Intelligent Auto Start/Stop function uses this information to adapt to various traffic situations in a proactive manner. For instance, this applies to the following situations: When a situation is detected in which the stopping time is expected to be very short, the engine is not switched off automatically. A message appears on the Control Display, depending on the situation. When a situation is detected in which the vehicle needs to drive off immediately, the engine is started automatically. The function may be restricted if the navigation data is invalid, outdated or not available, for example. |
radmjk241.50 |
08-12-2020, 10:19 PM | #6 | ||
Rep 589
08-12-2020, 10:21 PM | #8 |
Rep 3,413
08-12-2020, 10:25 PM | #10 | |
Rep 589
sygazelle11529.00 |
08-13-2020, 03:00 AM | #11 |
Rep 243
zhangyi17 You will be surprised how nice your dashboard will look after you peel off the plastic film that BMW had put there to protect it during shipping.
08-13-2020, 04:09 AM | #12 | |
Rep 243
- You indicate that you don't want to turn off the engine by only lightly touching the brake pedal. - The car needs more power from the engine than what it would get from the battery if the engine was turned off. Last edited by Caramel; 08-13-2020 at 07:28 AM.. |
08-13-2020, 05:14 AM | #13 |
Rep 589
08-13-2020, 09:19 AM | #14 | |
Rep 1,952
ASS will not activate if... 1) you're in sport mode 2) it's so hot outside that the A/C cannot keep up w/o the engine running 3) you're in stop and go traffic, so it knows you will be starting back up immediately. |
08-13-2020, 01:19 PM | #15 | |
Rep 859
08-13-2020, 01:25 PM | #16 | ||
Rep 2,420
If this is the average consumption from factory for thousand miles it is quite high indeed. |
08-13-2020, 02:28 PM | #17 |
Rep 1,791
On my X7 40i I average between 20 and 22 mpg combined. Freeway driving at 60 -70 mph I average around 26 mpg. Freeway driving at 80 mph I average between 24 and 25 mph.
I consider this pretty impressive for such a big vehicle. |
08-13-2020, 02:42 PM | #18 | ||||||
Rep 336
08-13-2020, 02:51 PM | #19 | |||||||
Rep 2,420
I love the sound of the V8 engine but it is too expensive to put a car like that on a company in Europe. Taxes are ridiculously high. In Norway and The Netherlands taxes are more than the price of the car. In Belgium the tax difference between a 50i and 45e is 10-15k a year. I hope fuel prices are at US level in Canada and not a European level. |
08-13-2020, 08:51 PM | #20 | |
Rep 859
